Results 1 to 7 of 7
Thread: RR Web Cam Skin Help
    Jan 2006
    Hi,
    I managed to get "capture!" web cam app integrated to RR BVA2 skin.
    when I hit "RIP" button cam app opens up.(This is good)
    When hit any of the buttons on the cam skin (top left corner) cam skin exits and RR main skin appears as expected but cam app won't exit, it just goes to background.
    How do I get these two buttons "bind" to the app?
    Please check the pic for more clarification.
    My cam.skin file
    MEDIACAR Skin
    MEDIACAR "CAMSKIN" Skin
    /, C, x, y, w, h
    C01,000,090,800,600
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,700,0,65,85,"Close","Close"
    B02,750,0,65,85,"Exit","exit"
    /, A, x, y, w, h, color R;RGB, G, B
    A01,0,93,800,505
    END
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    hmm close should close the app, but not exit the skin.
    exit exits the skin but does not close the app.
    that's how they should work. unless RR has not actually embedded the app properly.
    what is the command you are using to 'call' the cam skin and !capture app?
    you could always put a "CLOSEWINDOW;<windoetitle of app>" as the close button.
    Jan 2006
    Hi,
    I've put below line in my menu.skin file to call the app.
    B02,348,70,104,75,"LOAD;cam.skin;cam;E:\Downoads\o ther Car Apps\Capture\Capture!\Capture!.exe"
    I have cam.skin file to call the skin.
    Do you mean to put something like this to my cam.skin file?
    B01,700,0,65,85,""CLOSEWINDOW;<windoetitle of app>","Close"
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by babyface
    Hi,
    OK well that line does not have the window title to embed so that is why the app is not closing down.
    try adding the window title after a ; at the end, like so (assuming Capture! to be the window title)
    B02,348,70,104,75,"LOAD;cam.skin;cam;E:\Downoads\o ther Car Apps\Capture\Capture!\Capture!.exe;Capture!"
    No, try (again assuming capture! to be the window title), although you shouldn't need this if doing the avbove works.
    B02,750,0,65,85,"CLOSEWINDOW;capture!||Exit","exit "
    Jan 2006
    Fixed
    Thanks Enfocer your tip worked!
    Step 1
    Menu.skin file
    Step 2
    cam.skin file
    MEDIACAR Skin
    B01,700,0,65,85,"Close","close"
    B02,750,0,90,85,"Exit","exit"
    A01,0,93,800,505
    /, C, x, y, w, h
    C01,000,090,800,505
    END
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Now if you could get that screen to come up when reversing the car ( and may be mirror the image too ? ).....
    Terran
  1. Best RR Skin for BMW
    By dasha877 in forum Road Runner
    Last Post: 06-27-2006, 06:55 PM
  2. pink transparency not working if skin is resized by RR
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 02-06-2006, 01:23 AM
  3. How to show many web page in rr
    By dabper in forum Road Runner
    Last Post: 01-17-2006, 03:32 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Min Requirements for a web cam
    By edie209 in forum Off Topic
    Last Post: 05-17-2001, 04:50 PM
