Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Roadrunner crashing on startup
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    I'm at the stage in my system testing where I'm trying out the latest version of Roadrunner to use as a frontend. I've tested the app on one of my workstations and it started up and ran perfectly.
    When I transferred it to my carPC (EPIA MII-12000, onboard video, win2kpro svcpk4, 512 RAM, onboard sound, MTSVO-SC LCD with touchscreen drivers installed, DirectX 7.0, running at 800x600 and trying the Kuo Clean Skin) it crashes on startup. I get the error:
    "rr.exe has generated errors and will be closed by Windows. You
    will need to restart the program.
    An error log is being created."
    Anyone know what a likely cause of this might be? I have winamp 2.95 installed on the system, but so far I have left the Winamp settings in roadrunner blank. (I have not pointed it to the winamp path). On startup, it seems to be crashing right at the point where the text says "Starting winamp ..." After it crashes, my windows taskbar has disappeared from the screen.
    I added the winamp path to the rrconfig app, and RR still crashes, but winamp stays open on the screen after RR crashes.
    [EDIT:
    I tried changing the MII-12000 BIOS setting for display type from LCD to CRT, but this didn't make a difference.
    I also removed the MTSVO touchscreen and put a regular CRT monitor on the system to test if the touchscreen might have been causing the problem. Roadrunner still crashes on startup with a regular monitor.]
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    can you post your rr.ini ? This type or error is very unusual.. you can also add this line to RR.INI and look at the debug log:
    debugmode=true
    Ride Runner RR's Myspace
    Jul 2005
    NJ
    For testing, I just wiped out my entire RR directory and unzipped a fresh RR-binary copy into the old directory. I then ran the config, and set up the day/night skin settings, and saved the config. I then added the debugmode=true setting to the rr.ini file and ran RR. It crashed again. Here is the info:
    rr.ini (basically untouched):
    voice=false
    musicpath=Click here to set path
    videopath=Click here to set path
    dvdpath=Internal
    launchpath=Click here to set path
    winamppath=Click here to set path
    skinpath=D:\utility\roadrunner\Skins\800x600_clean_day\
    nightskin=D:\utility\roadrunner\Skins\800x600_clean_night\
    mpcpath=Click here to set path
    screentype=4:3
    videoautohide=true
    videohidetime=4
    hidemouse=false
    albumart=*.txt
    useid3=1
    showid3playlist=false
    showid3browse=false
    mappointmap=1
    mapautozoom=true
    mapcountry=United States
    mapcity=
    gpsmode=3
    gpsport=0
    mapmonkeypath=Click here to set path
    gpspath=Click here to set path
    gpsname=
    exitmode=0
    showicons=false
    showextensions=false
    titlesafter=-
    listfollowssong=true
    resumemusic=0
    audiorepeat=off
    audioshuffle=off
    gammamode=2
    dateformat=Short Date
    timeformat=Long Time
    id3listformat=%title%
    id3browseformat=%title%
    mastervolmap=0
    listnumbers=true
    noformat=false
    hidewinamp=false
    visuname=MilkDrop
    overspeed=55
    scrollmode=1
    builtinvideo=true
    disableinternat=false
    locale=0
    hidetaskbar=false
    hidedesktop=false
    radiomode=0
    radioline=0
    lazytag=false
    allowallfreqs=false
    browsertype=1
    browserpath=Click here to set path
    debugmode=true
    And here is the debug.txt file:
    4/1/2006 11:33:46 PM: Start
    4/1/2006 11:33:46 PM: Master Vol: Master Volume/4
    4/1/2006 11:33:46 PM: GetLineControl Failed: 401
    4/1/2006 11:33:46 PM: No Treble Support
    4/1/2006 11:33:46 PM: No Bass Support
    4/1/2006 11:33:46 PM: Source: Wave=&H1008/1
    4/1/2006 11:33:46 PM: Source: SW Synth=&H1004/2
    4/1/2006 11:33:46 PM: Source: 3D Depth=&H100A/3
    4/1/2006 11:33:46 PM: No Mute for Source
    4/1/2006 11:33:46 PM: Source: Mic=&H1003/4
    4/1/2006 11:33:46 PM: Source: Line In=&H1002/5
    4/1/2006 11:33:46 PM: Source: CD Player=&H1005/6
    4/1/2006 11:33:46 PM: Source: Video=&H100A/7
    4/1/2006 11:33:46 PM: Source: Aux=&H100A/8
    4/1/2006 11:33:46 PM: Source: Phone=&H1006/9
    4/1/2006 11:33:46 PM: Source: PC Speaker=&H100A/10
    4/1/2006 11:33:46 PM: Source: Wave=&H1008/11
    4/1/2006 11:33:46 PM: Can't Open Source
    4/1/2006 11:33:46 PM: Winamp window not found.
    4/1/2006 11:33:46 PM: Shell: "Click here to set pathwinamp.exe"
    4/1/2006 11:33:46 PM: Winamp executable not found.
    4/1/2006 11:33:47 PM: Winamp window not found.
    It's strange that it's saying "winamp window not found" since I haven't configured the winamp path, but it looks like the error is being caused by something with the onboard sound: GetLineControl Failed: 401
    Hopefully this isn't too big a deal to figure out...
    '01
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I would strongly suggest to test it with Winamp/music/video paths setup.. RR should time out in 5 seconds after trying to start winamp.. but not crash.. the "failed" on the sound cards just means it doesn't support that feature..
    IMHO it sounds like you may have some hardware issue coming up at high CPU LOAD and/or intensive memory operations.. can you post information or a screenshot of the DETAILS of the windows error ?
    Jul 2005
    NJ
    Where would the details of the windows error be found? The only thing in the crash window that pops up is what I posted above about "rr.exe has generated errors, etc etc" with either an "OK" or a "CLOSE" button (I can't recall which right now). There are no details beyond that.
    I don't think it's a CPU/RAM instability as the machine overall is extremely stable even under high load. I've had it running at close to 95% CPU load for extended periods while testing. I tested starting RR again with the winamp/music paths set, and I had the windows task manager open. The CPU usage doesn't go above 50% on RR starting up, and the memory usage doesn't go above 70Mb. The system at startup is using approx 50Mb RAM.
    This is the rr.ini file as it is now:
    voice=false
    musicpath=D:\music\
    dvdpath=Internal
    winamppath=C:\Program Files\Winamp\
    mpcpath=C:\Program Files\Windows Media Player\mplayer2.exe
    screentype=4:3
    videoautohide=true
    videohidetime=4
    audiofiles=mp3
    hidemouse=false
    albumart=*.txt
    useid3=1
    showid3browse=false
    mappointmap=1
    mapautozoom=true
    mapcity=
    gpsmode=3
    gpsport=0
    gpsname=
    exitmode=0
    showicons=false
    titlesafter=-
    resumemusic=0
    audiorepeat=off
    audioshuffle=off
    gammamode=2
    mastervolmap=0
    listnumbers=true
    noformat=false
    hidewinamp=false
    visuname=MilkDrop
    overspeed=55
    scrollmode=1
    builtinvideo=true
    locale=0
    hidetaskbar=false
    hidedesktop=false
    radiomode=0
    radioline=0
    lazytag=false
    allowallfreqs=false
    browsertype=1
    browserpath=C:\Program Files\Internet Explorer\IEXPLORE.EXE
    debugmode=true
    and this is the debug output:
    4/2/2006 11:47:17 AM: Start
    4/2/2006 11:47:17 AM: Master Vol: Master Volume/4
    4/2/2006 11:47:17 AM: GetLineControl Failed: 401
    4/2/2006 11:47:17 AM: No Treble Support
    4/2/2006 11:47:17 AM: No Bass Support
    4/2/2006 11:47:17 AM: Source: Wave=&H1008/1
    4/2/2006 11:47:17 AM: Source: SW Synth=&H1004/2
    4/2/2006 11:47:17 AM: Source: 3D Depth=&H100A/3
    4/2/2006 11:47:17 AM: No Mute for Source
    4/2/2006 11:47:17 AM: Source: Mic=&H1003/4
    4/2/2006 11:47:17 AM: Source: Line In=&H1002/5
    4/2/2006 11:47:17 AM: Source: CD Player=&H1005/6
    4/2/2006 11:47:17 AM: Source: Video=&H100A/7
    4/2/2006 11:47:17 AM: Source: Aux=&H100A/8
    4/2/2006 11:47:17 AM: Source: Phone=&H1006/9
    4/2/2006 11:47:17 AM: Source: PC Speaker=&H100A/10
    4/2/2006 11:47:17 AM: Source: Wave=&H1008/11
    4/2/2006 11:47:17 AM: Can't Open Source
    RR goes through the startup screen, then hits the "Starting Winamp..." portion. Winamp starts up properly and sits at the top-right of the screen, then RR crashes, and winamp stays open. After RR crashes, winamp is still functional: I can navigate its menus, open and close the playlist editor, equalizer, etc.
    '01
    Low Bitrate pwcmed's Avatar
    Jul 2005
    San Antonio, TX
    I don't if this helps but I had a problem with RR crashing and it turned out to be the skin I was using. It was the slider code that was causing the issue.
    Jul 2005
    NJ
    Yeah I thought about that, so I've now tried 5 different skins, all with the exact same result. I also tried booting into safe mode and running RR and it crashed at exactly the same point.
    I'm going to try connecting a PCI video card and seeing if it has something to do with the onboard video.
    I'm also going to try reloading windows from scratch and then loading RR as the first app, before any others, and seeing if I can track down some kind of conflict that way. However, I don't think it's a hardware issue.
    '01
    guino's Avatar
    Nov 2004
    Toronto, Canada
    have you tried loading differen files on winamp before starting RR ? please let me know.. You may also try to disable ID3 support and/or delete main.* in the winamp\plugins\ml folder to see if it helps.. your INI seems pretty basic with no weird/advanced features.. so there's really no reason why it shouldn't work. The details for the windows error are normally displayed by clicking a "link" in the popup window with the ok/close buttons.
    Jul 2005
    NJ
    Well, I've been testing my system under windows XP SVC PK 2, and on a whim I tried Road Runner again. It worked without any problems, so it had to be something with my specific installation of win2k SVC PK 4. Strange.
    One thing I've noticed though is that when I first ran Road Runner, I had winamp configured to show just the Track Title. I played around with it a bit, and then changed it to Artist - Album - TrackTitle. However, any albums from which I had already played a few tracks (when it was still configured for just TrackTitle) still showed just the TrackTitle, and did not display Artist - Album - Track Title.
    '01
    Variable Bitrate redbullah's Avatar
    Mar 2006
    Belgium
    I have exactly the same problem right now.
  1. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  2. DVD = crashing on startup
    By amthar in forum StreetDeck
    Last Post: 03-03-2006, 10:31 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  4. Phoco crashing?
    By Cruizer in forum PhoneControl
    Last Post: 11-18-2005, 05:54 AM
  5. RoadRunner and Freedrive at Startup
    By Cruizer in forum Road Runner
    Last Post: 11-18-2005, 04:35 AM
