Page 15 of 55 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 545
Thread: Release new phoco integration preview
  1. #141
    May 2005
    The other thing left to check is the filename of your pictures. Make sure they are named exactly as your phone contact names. Maybe try using a different HOME.JPG file?
  2. #142
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by DonkeyBoy
    OK, so i have removed the "/, F, x, y, w, h, Movie name
    F01,342,89,120,150,"PHOCO_IMAGE.swf"
    from my skin file and left in the
    "/, J, x, y, w, h
    J,342,89,120,150"
    i have set path to images in rr config. does not work. what next ?
    The picture file name must be the same name that appear in the label "CALL_NAME_PHOCO", when the call is incoming or outcoming, + ".jpg".
  3. #143
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Quote Originally Posted by Robby BMW
    Does this option only work for phoco v. 1.6b??
    Have tried in phoco v 1.51 and haven't got it to work?
  4. #144
    Aug 2005
    Italy
    Quote Originally Posted by wfs1
    It work with all versions.
  5. #145
    Aug 2005
    Italy
    I have edited my rrini to add this
    "phonelistspath=C:\Program Files\Road Runner\PHOCOimages\"
    Anyone any ideas ???
    Your problem is the setting above, "phonelistspath" is for the phonebooks, calls and sms lists path.
    The correct setting for contacts' pictures is "contactspicturespath", so the line above would have to be:
    "contactspicturespath=C:\Programmi\RoadRunner\PHOC OImages\"
  6. #146
    Mar 2004
    I am using Widcomm_5[1][1].0.1.801_bluetooth_drivers.exe when i try to pair deivce, and select services, it doesnt show Audio gateway. What do i do? do i need that?
  7. #147
    Aug 2005
    Italy
    RR PhoCo integration settings
    I think it will be appreciated a little resumen of all settings used in RR.ini concerning the PhoCo integration:
    phocopath=<PATH TO PHOCO.EXE>
    Path to PhoneCtl.Net.EXE (Zorro's Phone control application -- if used).
    phoconodesign=0|1
    Phone Control launch mode: 1=Launch PhoCo with NoDesign feature (Faster)
    phoconoincallevent=0|1
    Use Phone Control In Call event? (0=Use the InCall event 1=Don't use the InCall event) Usually it must has to be set to "true" (1)
    ringtone=<PATH TO RINGTONE FILE.WAV>
    Path to Ring Tone file for incomming calls.
    smstone=<PATH TO SMSTONE FILE.WAV>
    Path to SMS Tone files for incomming SMS alerts.
    phonelistspath=<PATH TO INTERNAL ADDRESSBOOK, CALLS and SMS FILES.XML>
    Tell to RR where to store phonebooks and phone information files. If omitted, RR will save the files in the installation directory.
    contactspicturespath=<PATH TO CONTACTS PICTURES>
    Path to contacts' pictures files.
    standardphonebook=0|1|2
    Default PhoneBook List view (0=Internal, 1=Phone, 2=SIM Card)
    maxcalllistentries=<MAX CALLS TO KEEP IN CALL LIST FILE>
    Defines how many entries we should store in the call lists.
    connecthsp=0|1
    Manage the audio gateway by RR instead of PhoCo? (0=No, 1=Yes)
    btdevicename=<PHONE NAME>
    Bluetooth name of your phone (Used to manage the audio gateway)
  8. #148
    Aug 2005
    Italy
    Quote Originally Posted by hoodlum
    Take a look at this document it show you the steps on a SonyEricsson T610, but the procedure is similar in the greater part of phones.
  9. #149
    Oct 2005
    Arkansas
    Phoco images
    Have the following in my rr.ini file
    contactspicturespath=C:\Program Files\Road Runner\PHOCOImages\
    Have two jpgs in the C:\Program Files\Road Runner\PHOCOImages\
    under the entries for "CALL_NAME_PHOCO",phonebook, etc
    Work
    Home
    My call in skin entries;
    MEDIACAR Skin
    MEDIACAR "IncomingCall" Skin
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,12,402,158,89,"ACCEPT_CALL_PHOCO",""
    B02,175,403,158,89,"IGNORE_CALL_PHOCO",""
    B03,339,403,158,89,"HANGUP_CALL_PHOCO",""
    /, J, x, y, w, h
    J01,2,2,506,196,".jpg"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES,
    Tooltip;LABELALIGNMENT
    L01,30,238,449,42,255,255,0,25,"GE Drover","CALL_NAME_PHOCO",""
    L02,30,294,449,42,255,255,255,25,"GE Drover","CALL_NUMBER_PHOCO",""
    L03,31,354,449,31,19,46,76,20,"GE Drover","CALLSTATE_PHOCO",""
    END
    My call out skin entries;
    MEDIACAR Skin
    L01,33,239,449,42,255,255,0,25,"GE Drover","CALL_NAME_PHOCO",""
    L02,33,294,449,42,255,255,255,25,"GE Drover","CALL_NUMBER_PHOCO",""
    /, J, x, y, w, h
    J01,2,2,507,197,".jpg"
    L03,33,351,449,31,19,46,76,20,"GE Drover","CALLSTATE_PHOCO",""
    END
  10. #150
    Aug 2005
    Italy
    Work
    Home
    MEDIACAR Skin
    /, J, x, y, w, h
    END
    MEDIACAR Skin
    /, J, x, y, w, h
    END
    Have you two contacts named "Work" and "Home" stored in your phone contacts list?
    When you receive a call from one of this two contacts, what name is showed in your call in skin and your phone display?
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 06:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 10:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 01:56 AM
