Page 16 of 55 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 545
Thread: Release new phoco integration preview
  1. #151
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Quote Originally Posted by Robby BMW
    Have you two contacts named "Work" and "Home" stored in your phone contacts list?
    When you receive a call from one of this two contacts, what name is showed in your call in skin and your phone display?
    Contacts are Work and Home. They showup as Work or Home in my cell phone. They showup in the phoco skin as such and when I receive an incoming call they show as Work or Home. The speech engine says "Work" or "Home".
    To test with;
    I made a new entry in my cell phone phonebook called "Zero".
    Then used a landline phone number that I entered for "Zero" to test with. Updated my cell phonebook etc.. Then a made a jpg called "Zero" copied it to the Phocoimage directory. Made sure the jpg didn't have any hidden attributes.
    Started RR/phoco. Reloaded phonebook and tested. Still no image on the inbound call.
    I'm using the lastest RR.
  2. #152
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    All that you have done is correct, it would have to work.
    The only difference that I have noticed between my skin and your one, is this:
    my skin:
    /, J, x, y, w, h
    J01,342,89,120,150
    your skin:
    /, J, x, y, w, h
    J01,2,2,506,196,".jpg"
    it would have to be irrelevant, but try to change your part of skin in:
    /, J, x, y, w, h
    J01,2,2,506,196
    Another question: The complete name of the jpeg in your sample is "zero" or "zero.jpg"?
  3. #153
    Mar 2004
    where can i download phonecontrol v1.5?
  4. #154
    Oct 2005
    Arkansas
    my skin:
    /, J, x, y, w, h
    J01,342,89,120,150
    your skin:
    /, J, x, y, w, h
    /, J, x, y, w, h
    J01,2,2,506,196
    I tried with and without the .jpg at the end of J01,2,2,506,196 before I posted here.
  5. #155
    Aug 2005
    Italy
    Quote Originally Posted by wfs1
    Therefore the things are two, or the contacts' pictures path that you have entered in "contactspicturespath" is incorrect or your system is configurated to hide the known file extensions, in this case the real file name of your jpeg would be "Zero.jpg.jpg" (the second ".jpg" is hiden).
  6. #156
    Low Bitrate DonkeyBoy's Avatar
    Mar 2005
    Stockport UK
    thanks for all the help. will try it tom.
    VIA EPIA M10000 LVDS 1Ghz Motherboard,
    256Ram,80Gig,
    Lilliput 7" In Dash Touchscreen
    Panasonic Slimline Slot-in Cdrw/dvd Player,
    USB Gps Reciever,
    Belkin Bluetooth dongle
    Belkin USB wifi
    Carnetix CNX-P1290 60W Power Regulator
  7. #157
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    Hi peijffertje,
    I've double checked the code in order to find something that can cause the problems that you have said but without results.
    However I'm very interesting in these issues, can you exec rr in debug mode and post your log file? This will be very helpful
    Hi Robby,
    Here is the log of my debug file.
    After I start RR.. it will load everything and then hangs eacht time I start RR after a cold boot.
    Thanks for looking at it!
    5/11/2006 9:10:56 PM: Start -- Version: 5/2/2006
    5/11/2006 9:10:56 PM: Master Vol: Volume Control/4
    5/11/2006 9:10:56 PM: GetLineControl Failed: 401
    5/11/2006 9:10:56 PM: No Treble Support
    5/11/2006 9:10:56 PM: No Bass Support
    5/11/2006 9:10:56 PM: No Master ON/OFF
    5/11/2006 9:10:56 PM: Source: Wave=&H1008/1
    5/11/2006 9:10:56 PM: Source: SW Synth=&H1004/2
    5/11/2006 9:10:56 PM: Source: Line Out=&H100A/3
    5/11/2006 9:10:56 PM: Source: 3D Depth=&H100A/4
    5/11/2006 9:10:56 PM: Source: Video=&H100A/5
    5/11/2006 9:10:56 PM: Source: CD Audio=&H1005/6
    5/11/2006 9:10:56 PM: Source: Line In=&H1002/7
    5/11/2006 9:10:56 PM: Source: Microphone=&H1003/8
    5/11/2006 9:10:56 PM: Source: Phone Line=&H1006/9
    5/11/2006 9:10:56 PM: Source: PC BEEP=&H1008/10
    5/11/2006 9:10:56 PM: Winamp window not found.
    5/11/2006 9:11:00 PM: Shell: "C:\Program Files\Winamp\winamp.exe"
    5/11/2006 9:11:10 PM: Enter Exec: False, menu.skin, , False
    5/11/2006 9:11:10 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    5/11/2006 9:11:10 PM: Executing:
    5/11/2006 9:11:10 PM: Leave Exec: False, menu.skin, , False
    5/11/2006 9:11:13 PM: Enter Exec: False, menu.skin, , False
    5/11/2006 9:11:13 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
    5/11/2006 9:11:13 PM: Executing:
    5/11/2006 9:11:13 PM: Leave Exec: False, menu.skin, , False
  8. #158
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Help Please on Phoco Config
    I'm new to Phoco, and I'm having a few problems...can someone help please.
    Setup is T610, Phoco 1.5.1, Roadrunner (latest), Mapmonkey,BMV Skin.
    Problem 1
    I can run Phoco sucessfully on its own, but when I try to launch it via RoadRunner, I get "Failed to load resources from resources file. Please check your Setup" The only way I can use the RR Phoco screen is to launch Phoco first independently, then RR.
    I'm also having the "out of hibernation problem" too... has this been fixed ?
    Problem2
    @ Robby BMW
    I've implemented all your recommendations. I get my current Album Art showing in the RR phoco_in/phoco_out screens instead of a contacts jpeg.
    @ Robby BMW
    Where are your Phoco_in/_out screens from ?
    Wizz_r
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  9. #159
    May 2005
    Quote Originally Posted by wizz
    Problem 1
    Problem2
    @ Robby BMW
    @ Robby BMW
    Wizz_r
    Problem 1: I am using v1.5.1 too. Yes, I do get the same the error. But only when resuming from a standby or hibernation with my phone NOT in the bluetooth range or with bluetooth disabled. In other words, Phoco is not able to connect to my phone. Turning the bluetooth on subsequently doesn't help and the only way to use the phone features within RR again is to restart RR which in turns restarts Phoco.
    Problem 2 & 3: Perhaps Robby can upload a copy of his latest BMW skin which showcase all the Phoco features. The previous one which he shared is still using a flash to display the caller's photo.
  10. #160
    May 2005
    Problem 1
    Problem2
    @ Robby BMW
    @ Robby BMW
    Wizz_r
    Problem 1: I am using v1.5.1 too. Yes, I do get the same the error. But only when resuming from a standby or hibernation with my phone NOT in the bluetooth range or with bluetooth disabled. In other words, this error pops up when Phoco is not able to connect to my phone. Turning the bluetooth on subsequently doesn't help and the only way to use the phone features within RR again is to restart RR which in turns restarts Phoco.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 06:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 10:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 01:56 AM
