Page 18 of 55 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 545
Thread: Release new phoco integration preview
  1. #171
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Robby BMW
    Which RR release are you running?
    The very latest.
    I can run Phoco on its own with no problems. Once I try to run it via RR, thats when I have to "mess about" minimising RR and re-starting bluetooth before I can use it integrated.
    It looks like when RR boots and loads Phoco it stops my bluetooth.
    I get a message from my Blue Soleil software saying bluetooth connected, then another saying disconected. Hence I have to minimise RR and re-start it manually.
    If I run Phoco independently, it starts bluetooth and it remains connected.
    How about the album art showing instead of my contact info, any ideas ?
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  2. #172
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    wizz;
    I never had very much sucess using the Blue Soleil software/drivers in the past. The widcomm drivers are the best.
  3. #173
    Oct 2005
    Arkansas
    Therefore the things are two, or the contacts' pictures path that you have entered in "contactspicturespath" is incorrect or your system is configurated to hide the known file extensions, in this case the real file name of your jpeg would be "Zero.jpg.jpg" (the second ".jpg" is hiden).
    I have check very throughly and I can use any program to view jpegs. My RR skins have a few jpgs that are being loaded with the /J entry. My audio browser for displaying older jpegs work in RR. I don't have the hidden file extension. I've changed and rename the phocoimage directory/path several times and still no contact image on inbound or outbound.
    My phonebook is being written to and read from properly with RR/phoco.
    How many here are seeing the phocoimage on calls???
  4. #174
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by wfs1
    wizz;
    Does this mean that I have to change my Bluetooth device to one that uses widcomm drivers ?
    PS: I get my current album art displayed in phone_in/phone_out screens, and not my contacts jpeg's.
    Wizz
  5. #175
    Oct 2005
    Arkansas
    Quote Originally Posted by wizz
    Wizz
    You might try to find the widcomm drivers, Goggle search . Logitech had some that worked fairly well.
    At least you're getting something to display?
  6. #176
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    bluesoleil devices will work with the widcomm drivers.
    Live mp3Car Facebook Chat
  7. #177
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    wizz;
    I personally have had no probs with my Blue soliel software,but i did have a nightmare trying to get the Widcomm stack to function properly with my soliel device.Now i use the Microsoft BT stack and my phone connects automaticly when i'm in range,only problem of course is this is only usefull for using your phone as a modem as the MS BT stack does not support the audio gateway.In the end i decided to use a car kit cradle and data cable for Phoco and i only use the BT for internet.A bit conventional but sometimes its the best way.
    It seems Phoco won't be with us in this guise for much longer anyway.I for 1 look forward to a decent hardware alternative.
  8. #178
    Nov 2004
    Leicestershire UK
    Thanks,
    I found the latest widcomm drivers with a stack unlock patch, and they now work with both my desktop and carpc bluetooth dongles.
    I'm going to try them out shortly in the carpc with roadrunner/phoco to see if this solves any of my problems.
    I take it you mean the album art in phone_in/phone_out screens.
    I'm going to check the config on that in rr.ini & skins.ini's I think the problem may lie there.
    Wizz
  9. #179
    Nov 2004
    Leicestershire UK
    Widcomm
    The widcomm drivers solved none of my problems.
    I'm about to give up unless someone can tell me where I am going wrong
    When I load Phoco independently it works perfect
    When I load it through RoadRunner it's very iffy... I get the "resources error" and have to either load phoco or Roadrunner again, until I eventually get it going through the RR Phoco screen (God knows how !). From then on it stays running OK until I return from a hibernation.
    It's therefore a RoadRunner integration problem
    Is there something I'm overlooking in the RR config that is stopping it working
    Help, it's driving me loco
    Wizz
  10. #180
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    ok i downloaded the latest RR release, i have a licensed phoco 1.6 beta, when i use phoco using the phoco program, it works, but when i use RR , at startup, i get an error with phoco saying that i dont have the correct port number, then it just closes. when i exit from RR and run phoco again, it works, why??? help. thanks. using IOGEAR bt dongle with widcomm 4.01.2101
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
