Page 2 of 55 FirstFirst 12345678910111252 ... LastLast
Results 11 to 20 of 545
Thread: Release new phoco integration preview
  1. #11
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    @ tbird: Yes, in the next coming soon preview, RR will close phoco when enter in hibernation and will restart it when come out.
    @ wfs: Well, in effects I've made some changes.
    Now phoco.ini is only for the language settings.
    #unknown_caller=Unknown
    #incoming_call=Call From:
    #in_call=In call:
    #outgoing_call=Dialing:
    #intPhoneBook=Internal Contacts
    #phonePhoneBook=Phone Contacts
    #simPhoneBook=Sim Card Contacts
    #allCalls=All Calls
    #inCalls=Incomming Calls
    #outCalls=Dialed Calls
    #missedCalls=Missed Calls
    #SMSin=SMS Inbox
    #SMSout=SMS Outbox
    #SMSsent=SMS Sent
    #SMSarchiv=SMS Archived
    All the parameters inherent to the configurations are been moved to rr.ini (that is the most appropriated place for this).
    At the moment the PhoCo's settings accepted by RR are the following:
    phocopath=<PATH TO PHOCO.EXE>
    Path to PhoneCtl.Net.EXE (Zorro's Phone control application -- if used).
    phoconodesign=0|1
    Phone Control launch mode: 1=Launch PhoCo with NoDesign feature (Faster)
    phoconoincallevent=0|1
    Use Phone Control In Call event ? (0=Use the InCall event 1=Don't use the InCall event)
    ringtone=<PATH TO RINGTONE FILE.WAV>
    Path to Ring Tone file for incomming calls.
    smstone=<PATH TO SMSTONE FILE.WAV>
    Path to SMS Tone files for incomming SMS alerts.
    phonelistspath=<PATH TO INTERNAL ADDRESSBOOK, CALLS and SMS FILES.XML>
    Path to store phonebooks and phone information files.
    standardphonebook=0|1|2
    Default Phone List view (0=Internal, 1=Phone, 2=SIM Card)
    maxcalllistentries=<MAX CALLS TO KEEP IN CALL LIST FILE>
    Defines how many entries we should store in the call lists.
    connecthsp=0|1
    Manage the audio gateway by RR instead of PhoCo? (0=No, 1=Yes)
    btdevicename=<PHONE NAME>
    Bluetooth name of your phone (Used to manage the audio gateway)
    Take a look at the 1# post of this thread to see more details concerning the last two parameters.
  2. #12
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Are you able to make it drop the audio gateway connection when the call is over? It sucks because when my phone gets connected to my pc via audio gateway it doesn't close it.. Upon hibernation it won't hibernate unless I click on "OK" to close it...
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  3. #13
    Sep 2005
    UK
    Quote Originally Posted by Robby BMW
    I don't understand what you are talking about
    When a call comes in, RR send a PAUSE comand to the player and load (if exists) an EQ preset named PHOCO.PST. When the call ends, the previous EQ state is restored and the player comes back to PLAY mode.
    Please, may you confirm that this does not happen?
    Sorry I didn't realise rr did this for me. I will have a look and let you know my findings. Thanks
  4. #14
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Robby BMW
    Thanks, for all your hard work and your post clears up a lot of questions.
  5. #15
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    awesome work, and awesome timing bro.
    i just got the VX6700 and got phoco working with it, but only version 1.6 cause it is a smart phone.
    I'm going to wait until next pay period to buy this version, but cant wait to try your mods to RR on it. I'd love to have RR working with phoco, including fixing the hibernation issues.
    I'm guessing that most of you are using your speakers/microphones for your set ups?
    i think that would create too much feedback, so I found this solution on phoco.net for setting phoco to deliver the audio to my bluetooth headset correctly
    http://zhorvat.dyndns.org/PCForums/S...px?PostID=1422
    Also, i HIGHLY, HIGHLY reccomend the VX6700 over all the other smart phones out there.
    The buttons are much bigger and easier to handle then the treo, it has built-in wifi (which you can configure with some registry hacks to work simultaneously with your voice service) and it costs $100 less than the treo 700W.
    Reallly a great buy, I'm loving it....can't wait for it to be a central part of my RR setup!
  6. #16
    Aug 2005
    Italy
    Quote Originally Posted by tbird2340
    Is in my intentions to solve this problem too....
  7. #17
    Mar 2006
    Italy
    Hi,
    Sorry I have a motorola V3 and with this modify now I can use it with RR and Phoco but I don't understand how to route phone audio to pc speaker and mic.
    It is possible to use the PC audio (mic and speaker) to answer a call?
    If yes...wich settings in Phoco: controlled by RR or by Winamp?
    Any other setting in RR?
    Alex
  8. #18
    May 2005
    Quote Originally Posted by Alx0363
    Alex
    That's a function of your bluetooth stack. You need to install the Widcomm Bluetooth stack v1.4 or above. The current release are v5.0.x.x. With this bluetooth stack, your PC will support the Audio Gateway service which allows another bluetooth device (in this case, your mobile phone) to transfer it's audio wirelessly to your PC's speakers and microphone. The default WinXP bluetooth stack does not support such a feature.
  9. #19
    Oct 2003
    Poland, OH
    I'm using Broadcom 4.0.1.700 and it still does it?
    Slightly off topic: Sounds like you may know BT pretty good.. I got a question for you.. When I make / accept a call and my phone connects to my computer via voice gateway, I can HEAR the caller through my car speakers but they cannot hear me. This totally puzzles me because I can have sound recorder open while in call and it records my voice!?!
  10. #20
    Aug 2005
    Italy
    Updated the 1st post
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
