Page 22 of 55 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 545
Thread: Release new phoco integration preview
  1. #211
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    thats the error message one gets when you try to run another instance of phoco
    Live mp3Car Facebook Chat
  2. #212
    Low Bitrate mrheat's Avatar
    Jun 2005
    Lower Bavaria/Germany
    @b8bboi: if you try killing the process instead of CLOSE_PHOCO
    @all: launching the 1.6 from centrafuse works, if this helps.
    resumes fine now.
  3. #213
    May 2005
    Vienna, VA
    Quote Originally Posted by mrheat
    Thanks. But I thought the purpose of "CLOSE_PHOCO" was to close Phoco altogether?
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  4. #214
    May 2005
    Vienna, VA
    okay, I tried forcefully killing PhoneCtl.NET.exe before executing RESUME_PHOCO but it still didn't work. Here's my simple BAT file.
    Code:
    "C:\Program Files\Road Runner\exec.exe" CLOSE_PHOCO
    ping -n 10 127.0.0.1 > nul
    taskkill.exe /F /IM PhoneCtl.NET.exe /T
    "C:\Program Files\Road Runner\exec.exe" RESUME_PHOCO
    (The "ping" stuff is just a way to "sleep" for about 10 seconds each).
    This is what I tried.
    1. Hibernate and resume.
    2. Run the BAT file above.
    3. Get the "Failed to load resources" error message. Phoco is gone.
    4. Close RR.
    5. Open RR. Phoco is started along and this time, it works.
    It looks like CLOSE_PHOCO doesn't totally detach Phoco from RR and shut it down.
  5. #215
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by RS200Z
    Here's a copy of my CALL_IN.SKIN:
    MEDIACAR Skin
    MEDIACAR "IncomingCall" Skin
    Phoco Calls_In&Out_OFF.jpg,Phoco Calls_In&Out_OFF.jpg,Phoco Calls_In&Out_DOWN.jpg,Phoco Calls_In&Out_DOWN.jpg
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,40,241,135,72,"ACCEPT_CALL_PHOCO",""
    B02,191,241,134,73,"IGNORE_CALL_PHOCO",""
    B03,340,241,138,73,"HANGUP_CALL_PHOCO",""
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,37,42,259,45,255,255,255,26,"Arial:B","CALL_NA ME_PHOCO",""
    L02,36,104,259,40,192,192,192,22,"Arial:B","CALL_N UMBER_PHOCO",""
    L03,75,176,163,30,255,0,0,20,"Arial Black","CALLSTATE_PHOCO","CENTER"
    /, J, x, y, w, h
    J,316,41,159,182
    END
    I've tested this in my PC and it works good. The only change that I've made is to add a number in the "J" command (however it would have to be insignificant).
    When I change the parameters, i.e. J01,316,41,159,364 I get that the contact's picture is dislayed with double height.
  6. #216
    Aug 2005
    Italy
    Quote Originally Posted by b8bboi
    Robby, I just tried the RESUME_PHOCO command and couldn't get it to work.
    1. If I start Phoco with RR, everything works fine.
    2. I made 2 test buttons on my skin. One is set to "CLOSE_PHOCO", the other "RESUME_PHOCO". I clicked CLOSE_PHOCO, Phoco is closed as expected. Then I clicked RESUME_PHOCO. Phoco starts but gives this error.
    Code:
    Failed to load resources from resource file
    Please check your Setup
    3. If I exit RR altogether and restart it (and start Phoco along), Phoco works fine again.
    The CLOSE_PHOCO command, send a <Quit/> remote comand to PhoCo, then it waits a second and if PhoCo is still runnig, it tries to kill the process, however, I've noticed that for some strange reason sometimes PhoCo refuses to close it self.
    When PhoCo enters in this stage, even a kill command sent by the windows task manager (CTRL+ALT+DEL) is not able to terminate the program.
    I think that this is also the reason for which a lot of peoples have issues with hibernate.
    I've got some news from Zorro for a possible solution of the problem with the next PhoCo release.
  7. #217
    May 2005
    Vienna, VA
    I see. Thanks for the explanation, Robby.
  8. #218
    Sep 2005
    Malaysia
    Close & resume buttons
    Hi guys,
    I am a newbie here and having the same problem with hibernation. Tried creating the buttons in the phoco skin as per below but nothing happens when I click on the buttons. What could I have done wrong? Help please.
    B09,546,449,123,054,"resume_phoco","Connect"
    B27,546,670,123,054,"close_phoco","Disconnect"
    Couteau
    Pug 406, 3.0 V6, NOS, RoadRunner CarPC
  9. #219
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by couteau
    Hi guys,
    have that same issue. Those commands do nothing for me.
  10. #220
    Aug 2005
    Italy
    Arrow New PhoCo integration 06-04-06 BETA
    based on the last RR release (06-03-06)
    In this release:
    * Added confirmation when delete SMS or contacts stored in the internal phonebook. (You must have the confirm.skin in your skin folder).
    * Improved commands "CLOSE_PHOCO" and "RESUME_PHOCO".
    This beta is out of date.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 06:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 10:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 01:56 AM
