Page 25 of 55 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 241 to 250 of 545
Thread: Release new phoco integration preview
  1. #241
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    How to SMS ?
    @ Robby BMW
    I'm using RoadRunner/BMV2/MapMonkey/Phoco
    Any idea how I get SMS working ? Everything else does !
    I've ported over your SMS skins because BMV2 doesn't seem to have them.
    What else, if anything, do I need to do. I click the SMS button in the BMV2 skin.....but nothing happens.
    Any ideas
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  2. #242
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    So, where can I actuallyh download this program?
    The first post doesn't have a link....
    Thanks,
    Rafster
  3. #243
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by wizz
    @ Robby BMW
    Any ideas
    Wizz
    You must copy all the parts of phoco skins because BMV2 is very outdated.
  4. #244
    Aug 2005
    Italy
    Quote Originally Posted by Rafster
    Thanks,
    Rafster
    Here
  5. #245
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Anyone running the V1.7 Phoco???
  6. #246
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i'm not brave enough yet lol
    Live mp3Car Facebook Chat
  7. #247
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Hi Robby,
    Been lurking for a while but I'm back updating my carpc and have just loaded the latest beta here as well as Phoco 1.7.
    A while back I had been in contact with hematec about adding support for dialing digits after the main phone number. This would be for voice mail system navigation, such as dialing '2' to listen to a message, then '76' to delete, etc.
    Just wondering if you had picked up his code that contained this functionality or not? I had hacked up a skin so that the callout screen also had a keypad, so I could test this functionality.
    Finally, I have my cell and work VM numbers stored in my phone with the passwords separated by waits. On the phone you press a button to send the next sequence of tones. Don't know if this could be supported but it would be great if it could.
    Thanks for all the hard work.
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  8. #248
    Aug 2005
    Italy
    Quote Originally Posted by Zogg
    Hi Robby,
    It would have to still work because I've change only little things in the hematec's code.
    Z
    I've to make some tests to check if it's possible to do with phoco in remote mode.
  9. #249
    Woodbridge, VA
    Blog Entries
    55
    robby help me make sense of this issue
    Weird issue goin on with the "SMS" command.
    I'm using my 2.5 skin which i built based on your skin. If i press the sms button on the main phoco screen the first pic is what i get. Basically it just loads my sms inbox into the main phoco screen (phoco.skin). However, if i press the sms button from ANY other screen (calls for example) it loads the second picture. I want to load the second picture when i press "SMS" from any phoco screen. As you can see from the buttons on the first pic i cant do anything with the sms from that screen.
  10. #250
    May 2005
    Vienna, VA
    The SMS command will load your SMS list onto phoco.skin if you have the P region defined. This is the way it used to work before Robby added his stuff.
    Either take out the P region from phoco.skin or change the SMS button on phoco.skin to "Load;sms.skin".
    Or maybe Robby can modify his code to check if there's sms.skin and switch to it for the SMS command.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
