Page 26 of 55 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 545
Thread: Release new phoco integration preview
  1. #251
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Dialling digits in the callout skin after the call has been placed doesn't seem to work any more. I'll keep checking my skin work but can you take a look at it Robby?
    Thanks,
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  2. #252
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by Sonicxtacy02
    Weird issue goin on with the "SMS" command.
    I'm using my 2.5 skin which i built based on your skin. If i press the sms button on the main phoco screen the first pic is what i get. Basically it just loads my sms inbox into the main phoco screen (phoco.skin). However, if i press the sms button from ANY other screen (calls for example) it loads the second picture. I want to load the second picture when i press "SMS" from any phoco screen. As you can see from the buttons on the first pic i cant do anything with the sms from that screen.
    b8bboi has given an ecellente explanation, I can only add that I'll change the code in the next release in order to check if "sms.skin" exists and than switch to it for the SMS command
  3. #253
    Aug 2005
    Italy
    Quote Originally Posted by Zogg
    Thanks,
    Z
    Send me your call_out.skin so I can test this feature and fix the issue.
  4. #254
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Robby BMW
    ok i'll wait til the next release instead of making changes to a pretty good skin. Thanks
    Live mp3Car Facebook Chat
  5. #255
    Apr 2005
    Plano, TX
    Hi Robby,
    I made the same mods to the BMW_E36 skin and got the same result. I think that's your skin so just use this call_out.skin file instead of the original. I didn't pretty this one up, just used the dial jpg's so you have a keypad.
    I went back and looked and this feature was put in the 10-31-05 RR version.
    Thanks for the help.
    Z
    Attached Files Attached Files
  6. #256
    Apr 2005
    Plano, TX
    Sorry, Robby, it does still work. My bad.
    There's a setting for the V500/V600 series of Motorola phones that Zorro has wrong in his default settings. When I updated to PhoCo 1.7 it reset it.
    This is one area though that could be improved on almost all skins IMO. The CALL_OUT skin should also have a keypad on it.
    Sorry for the mistake.
    Z
  7. #257
    Aug 2005
    Italy
    Z
    Don't worry Zogg
    I've created a new call_out skin with the numeric keyboard, if you want to give it a try, you can download it here: CALL_IN_OUT_SKIN.rar
  8. #258
    Apr 2005
    Plano, TX
    Thanks, Robby, I'll give it a test.
    I'm sure it looks better than my quick hack test posted previously.
    Cheers,
    Z
  9. #259
    Low Bitrate VaRMiT's Avatar
    Jul 2005
    is there a way that this works with a regular PCI modem or do you have to use this with Bluetooth?
  10. #260
    Apr 2005
    Plano, TX
    PhoCo works with a serial connection to your cell phone. That serial connection can be either a real serial port (serial/usb cable to your phone), a Bluetooth serial connection, or I think an IR serial connection (never had a phone with IR).
    You don't use a modem, although in Winders your phone should show up as a modem.
    Z
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
