lemme know if exit works for you. It still pops up for meQuote:
Originally Posted by b8bboi
Printable View
Quote:
Originally Posted by Robby BMW
If you can only get to SMSOUTDETAILS.skin from these 3 screens what are SMSNUMBER.skin and SMSNUMBER2.skin for?
The only part thats not working for me in my unconventional skin is the out going SMS,even the 4 seperate calls screens work,how much code is involved in adding new screens (is there any way to work in a GENERIC.skin) or an Ignored range of skin files that phoco ignores and but continues its command sequence from the last supported .skin file???
I'm just trying to think outside the box a little,considering the amout of screens in phoco,its very restrictive when it comes to skinning and more than a little difficult to navigate in its current guises.
Robby, this doesn't work. If I hit EXIT, the call_out skin will go away but it will popup again after about 5-10 seconds.Quote:
Robby, I did that. Phoco standalone reports the correct number but RR popup doesn't. It still always shows the same (wrong) number for me. :(Quote:
Is there anything else I can try?
Hello
I have a problem with making my own phonebook for the internal contacts. When I save a number from rr the number isn´t shown anywhere, that means rr didn´t save the number. The next thing I can see is, that rr only makes a SIMPB but on my phone there is no number on the sim. Could someone tell me how to create my own phonebook and how I could save my numbers from rr?
If I start phoco as standalone the right phonebook (I made with CSV converter) everything is working right. What have I to do, that rr reads the same phonebook and save the new numbers in there?
I have the same problem as b8bboi with showing the right number.
Ti-ejtsch
The problems I had with Phoco and my Motorola in the past were,Quote:
Originally Posted by Ti-ejtsch
1.. Not reading or updating either the sim or phone (phonebook) correctly, depending on how I setup the RR.ini to read the phoco phonebook would achieve different results and not always what I needed.
I decided to upload all my contacts in the mobile phone from the sim to the mobile's phonebook and no entries in the sim. Then set RR/phoco to read from phone.
the rr.ini setting..
standardphonebook=1
This resolved my problem , not the best answer but it worked for me..
Add the option "phoconoincallevent=true" in your rr.iniQuote:
I know... I've make some tests more and I've discovered that there is an issue with the PhoCo remote tcp interface, after a "<RefreshSMS />" request all incoming calls are displayed with an incorrect caller name and number (usually the ones of the last SMS recived).Quote:
I have already talked with Zorro about this issue and he has promised that he will look into it.
Which phone do you use? Is it full supported by PhoCo?Quote:
The SMSNUMBER.skin and SMSNUMBER2.skin are for forwarding SMS, however you can get to SMSOUTDETAILS.skin from every screen using the command "NEWSMS".Quote:
Originally Posted by Griff1
