Page 33 of 55 FirstFirst ... 232425262728293031323334353637383940414243 ... LastLast
Results 321 to 330 of 545
Thread: Release new phoco integration preview
  1. #321
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by b8bboi
    Thank you. I'll try that.
    lemme know if exit works for you. It still pops up for me
    Live mp3Car Facebook Chat
  2. #322
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by Robby BMW
    I know... I know... there is a lot of screens in PhoCo integration, but when I began to work in this I decided to don't touch the screens structure for compatibility reasons.
    Really the Write_Message.skin is the SMSOUTDETAILS.skin, but you can reach it only after you have selected a destination number for the SMS and this is possible only on the phoco.skin, contacts.skin or contactdetails.skin.
    If you can only get to SMSOUTDETAILS.skin from these 3 screens what are SMSNUMBER.skin and SMSNUMBER2.skin for?
    The only part thats not working for me in my unconventional skin is the out going SMS,even the 4 seperate calls screens work,how much code is involved in adding new screens (is there any way to work in a GENERIC.skin) or an Ignored range of skin files that phoco ignores and but continues its command sequence from the last supported .skin file???
    I'm just trying to think outside the box a little,considering the amout of screens in phoco,its very restrictive when it comes to skinning and more than a little difficult to navigate in its current guises.
  3. #323
    May 2005
    Vienna, VA
    You can add an "EXIT" button (B,x,y,w,h,"EXIT","") in your "CALL_OUT.skin", this will close your popup without hang up the current call and the popup will not be visualized until the next call.
    Robby, this doesn't work. If I hit EXIT, the call_out skin will go away but it will popup again after about 5-10 seconds.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  4. #324
    May 2005
    Vienna, VA
    Try this: Launch PhoCo stand alone (not embedded in RR) and, when a connection is established with your phone, click the SMS inbox button, then click the reload button and wait until the SMS stored in your phone are shown. Now make a call to your phone and look at the PhoCo popup that is displayed. If you got the same issue (incorrect caller number), I'm sorry, but there is nothing that we can do, the only thing is to hope for a PhoCo quick update with this issue patched, but it depends from Zorro.
    Robby, I did that. Phoco standalone reports the correct number but RR popup doesn't. It still always shows the same (wrong) number for me.
    Is there anything else I can try?
  5. #325
    May 2005
    Germany
    Hello
    I have a problem with making my own phonebook for the internal contacts. When I save a number from rr the number isn´t shown anywhere, that means rr didn´t save the number. The next thing I can see is, that rr only makes a SIMPB but on my phone there is no number on the sim. Could someone tell me how to create my own phonebook and how I could save my numbers from rr?
    If I start phoco as standalone the right phonebook (I made with CSV converter) everything is working right. What have I to do, that rr reads the same phonebook and save the new numbers in there?
    I have the same problem as b8bboi with showing the right number.
    Ti-ejtsch
  6. #326
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Quote Originally Posted by Ti-ejtsch
    Hello
    I have a problem with making my own phonebook for the internal contacts. When I save a number from rr the number isnīt shown anywhere, that means rr didnīt save the number. The next thing I can see is, that rr only makes a SIMPB but on my phone there is no number on the sim. Could someone tell me how to create my own phonebook and how I could save my numbers from rr?
    Ti-ejtsch
    The problems I had with Phoco and my Motorola in the past were,
    1.. Not reading or updating either the sim or phone (phonebook) correctly, depending on how I setup the RR.ini to read the phoco phonebook would achieve different results and not always what I needed.
    I decided to upload all my contacts in the mobile phone from the sim to the mobile's phonebook and no entries in the sim. Then set RR/phoco to read from phone.
    the rr.ini setting..
    standardphonebook=1
    This resolved my problem , not the best answer but it worked for me..
  7. #327
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Add the option "phoconoincallevent=true" in your rr.ini
  8. #328
    Aug 2005
    Italy
    I know... I've make some tests more and I've discovered that there is an issue with the PhoCo remote tcp interface, after a "<RefreshSMS />" request all incoming calls are displayed with an incorrect caller name and number (usually the ones of the last SMS recived).
    I have already talked with Zorro about this issue and he has promised that he will look into it.
  9. #329
    Aug 2005
    Italy
    Hello
    Ti-ejtsch
    Which phone do you use? Is it full supported by PhoCo?
  10. #330
    Aug 2005
    Italy
    Quote Originally Posted by Griff1
    The SMSNUMBER.skin and SMSNUMBER2.skin are for forwarding SMS, however you can get to SMSOUTDETAILS.skin from every screen using the command "NEWSMS".
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
