Page 38 of 55 FirstFirst ... 282930313233343536373839404142434445464748 ... LastLast
Results 371 to 380 of 545
Thread: Release new phoco integration preview
  1. #371
    May 2005
    Quote Originally Posted by Robby BMW View Post
    Sorry, I forgot this commad... just added at the list
    Robby, I think this is a typo error in the "REPLY" command. You listed it as "REPLAY". Since we are on this topic, I am not sure if you can recall sometime back I was asking if you can add another REPLY command (maybe REPLY2) which only use the sender's name and number (not the SMS text) in SMSOUTDETAILS.skin? I am not sure if anyone actually reply a SMS quoting the sender's message. Probably rarely used...
  2. #372
    Aug 2006
    I'm sorry, maybe a noob question but is this the PhoCo program itself? If I'm not mistaken, one needs to pay for the software, rite?
    Or is this those that requires the PhoCo software to run the 'intergrated PhoCo RR'?
    Thanks!
  3. #373
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by RS200Z View Post
    Thank you for report the typo, I've corrected the command list.
    The REPLY command without SMS text quoted is an interesting request, I can add this feature easily in the next release.
  4. #374
    Aug 2005
    Italy
    Quote Originally Posted by SentraVIP View Post
    Thanks!
    This is only the embedding of PhoCo in RR, to take it working you need a licensed copy of PhoCo (the trial version doesn't work embedded in RR) installed on your PC.
  5. #375
    Aug 2006
    Oh... That's what I thought. Thanks for the clarification.
    Appreciated it
  6. #376
    Aug 2005
    Italy
    New BETA (09-29-06) available for the download in the first post!
    This is a mini update. I've added just a couple of users' requests.
    * Added the ability to load and handle the Internal Phonebook in the contacts skin without PhoCo running (MGD request)
    * Changed the REPLY command. Now for default the command only pastes the sender's name and number and not SMS text in the SMSOUTDETAILS.skin. However is still possible to quote the text by adding the options "quoted" to the command ("REPLY;QUOTED") (RS200Z request)
  7. #377
    Sep 2006
    Ukraine, Dnepropetrovsk
    How o use international symbols in phone book (UTF-16 codepage)?
    Help me please
  8. #378
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    Phoco and Calls info
    I know this is not the best place for my problem and I left a post on Zorros' site.
    Has anyone seen the problem of the calls.xml file not updating in phoco directory?? I can't see dialed calls, etc. Phonebook is fine?? Checked my settings for a Motorola and they seem to be fine?? Did the calls.xml file get replaced with these latest patches I'm on v1.7.4..
  9. #379
    Oct 2005
    Arkansas
    Forget the previous post.
    I deleted the calls.xml file and regenerated it again once I found where the rr.ini file had pointed it to.
  10. #380
    Oct 2006
    Kiev, Ukraine
    Regarding UTF-16 encoding in RoadRunner. Same problem. In phoco I change UseCharset to USC2 and phonebook encoding to UTF16, so now I can see russian language in my phonebooks in PhoneControl. But when I start RoadRunner then it can't make visible phonebook, list is empty. Is any way to make UTF-16 visible in RoadRunner phonebook?
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 06:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 10:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 01:56 AM
