Yes, I have tried with the modified version of RR.Then disconnect the headset with exit buton (bug with version.4.april.2006 but no with 9.apr.2006) but not with hibernate buton..thanks again
Printable View
I've just realized that the problem is caused by the BT-Stack's alert that raise when you try to enter in hibernate mode with the BT-Headset connected.Quote:
Originally Posted by NOKIALKATEL
I'm afraid, there is no viable solution for this yet. :(
yes my exactly problem is this btstackserver popup alert...****
Your solutios is HSPDisconnect !!! :DQuote:
Try this little AutoIt script that I've create to auto close the "btstackserver popup alert" that rise when you try to enter in hibernation mode with the BT Headset connected.
Copy this script in your hard-disk and make a link in your windows startup folder, in order to get it auto running at windows startup.
Let me know if it will solve your problem...
If your popup window title is " ServerStackBT " ==> HSPDisconnect 1
If your popup window title is " BTStackServer " ==> HSPDisconnect 2
Okay, keeping up with some results.
I upgraded to version 1.6 beta of phoco but the results were the same in the 1.5x version and Motorola Phone.
The following two entries in the RR.ini file are needed whether you use bluetooth or a USB cable connection, or at least in my system (WinXP 2.4 GHZ with 512 Meg).
connecthsp=true
btdevicename=My phone <--- Your phone ID here
Having tried the USB cable and the Bluetooth connections separate and even together. They work independently fine.
The mic is active anytime there is a call in progress, even with no audio
bridge.
I am using the CFX skin and I can call any number but two in my contact list the received calls, missed calls, etc are okay. The two I can't call by highlighting are Work and Home entries. Not sure where this is at since Phoco doesn't see this problem. Might be in RR/Skin somewhere although this use to work.
When using the RR configuration if you toggle the option from:
connecthsp=true; to no/false, then there isn't an entry in the RR.ini of connecthsp=false or 0, so I guess if no entry, it means false?
Still developing the SMS skins, so haven't tested there.
Since I have a Motorola V551J then there are some other issues.
A note. If you have flip up phone and set it answer on flip-up/open lid then the phone needs to be open to work with RR/Phoco.
Will continue to work on this bit by bit for further tests.
This two entries are used only for conect the headset by a bluetooth connection, they do not have no effect with IR o USB cable connection.Quote:
Originally Posted by wfs1
Can you be a little more clear? The voice gateway is always connected?Quote:
It's sound like a skin issue, double check your "CHOOSE_DIAL_NUMBER.skin".Quote:
Yes, it's the same of false.Quote:
It could be a phone limitations that can be solved with a firmware upgrade.Quote:
Thank you for your feedback.
results were the same:btstackserver popup not auto close with with this little AutoIt script ....Quote:
Originally Posted by Robby BMW
:tard: What is the exact title of your popup window? ServerStackBT ?Quote:
BTStackserver
Ok, your popup window title is different from mine
Then this may be working: HSPDisconnect
Let me know...
