Page 43 of 55 FirstFirst ... 333435363738394041424344454647484950515253 ... LastLast
Results 421 to 430 of 545
Thread: Release new phoco integration preview
  1. #421
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    robby,
    it doesnt look like your changes made it into the latest rr update. can i have your source so i can merge the two?
    Live mp3Car Facebook Chat
  2. #422
    Woodbridge, VA
    Blog Entries
    55
    btw i created a new label:
    CONTACTPIC_PHOCO - returns the file path of the currently active contact's image. its tested working in all but contactdetails (dont use it havent tested it) and its neccessary for anyone creating a flash skin for phoco ( as i have )
  3. #423
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by Sonicxtacy02 View Post
    robby,
    I'm sorry Sonic but in the two last month I was very busy and I didn't have got the time to merge the changes with the last source code and to send it to Guino.
    I'll try to do it in the next days.
  4. #424
    Woodbridge, VA
    Blog Entries
    55
    no prob at all.. take ur time on it
  5. #425
    Nov 2006
    aaargh
    i have a problem getting rr and phoco to work
    i have the bmw e36 skin, phoco 1,7 registred, and rr 12-10-06
    everything is working fine in phoco alone, but when i start rr i can se on my phone(nokia n70) it has made a connection but, nothing is working. i canīt call/recive calls, i cant see my contacts, and when i try to dial manualy and push the call button nothings happens, and the digit display in rr goes blank.
    i have tried to open the phoco first and then rr but its still dont work
    please help i soon have pulled all my hair of
  6. #426
    Nov 2006
    uuups
    hello everybody.
    i i realy need some help.
    i cant get my phoco and rr to work. on it self the phoco is woorking properly.
    when i open rr i can se on my phone (nokia n70) there is a connection and in the task bare the phoco is open and bluetooth have made connection. but nothing is working i cant se my contacts i cant call/recive a call
    when i get a incomming call i hear the ring tone in the speakers and a pop up in the windows task bar telling me i have a incoming call but no pop up in rr and i cant pick it up in rr
    i have treid to open phoco first and then rr this make no different
    i have phoco 1,7 registred and rr 10-12-06
    please help soon i have pull all my hair off
    smaskeren
  7. #427
    Nov 2006
    I have the lastest RR update (2006/11/12) and the latest PhoneControl.net (1.7 - Trial).
    RR works fine in all areas BUT phone support
    Phoco works fine standalone with my SonyEricsson T39M cable connected to my laptop.
    RR loads Phoco at startup if I set the path to the Phoco executable.
    Using the BMV skins, if I click Phone on the main menu, the Phoco skin loads BUT beyond that, nothing else happens vis-a-vis RR and my cellphone.
    Anyone have any idea what I'm missing?
    Regards,
    Jim
  8. #428
    Aug 2005
    Italy
    The only way to use the trial version with RR is to run PhoCo manually before to start RR. This is because the trial dialog doesn't show up when PhoCo is started in remote mode.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  9. #429
    Nov 2006
    OK, that worked. Starting the trial version first, then RR.
    However, the phone audio is still played on the phone.
    I thought it (and the mic) flowed over the cable from/to the T39M and was outputted/inputed via Phoco/RR.
    Did I miss something?
    Regards,
    Jim
  10. #430
    Nov 2006
    Oops, I just checked the compatibility charts (I have had a lot of trouble with the PhoneControl web site) and seems the T39M is only supported by BT.
    But that is curious as it works just fine with a USB cable (DC-11 or some such) except for the audio or is that chart simply telling me how the audio is handled?.
    I guess I need to do more research.
    Anyone have nay comment?
    Regards,
    Jim
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
