Page 46 of 55 FirstFirst ... 3637383940414243444546474849505152535455 LastLast
Results 451 to 460 of 545
Thread: Release new phoco integration preview
  1. #451
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    (i believe you are in trial period if so then
    make (and i repeat MAKE) a shortcut to phonecontrol.exe.. (don't use the shortcut already on your desktop) right click on the shortcut and put this in the TARGET : "C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe" -remotenodesign
    then run rrconfig and put everything as robby has said before..
    run the shortcut first.(press the TRY button... then run RR..
  2. #452
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Looking at your PhoCo log file, I'm sure that is not established a TCP connection between RR and PhoCo and this happens because PhoCo is not started in "remote mode".
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  3. #453
    Aug 2005
    Italy
    Quote Originally Posted by Nomader View Post
    robby i have a problem here..
    whenever i have a call from an "unknown number" (secret telephone) then in the callers id it just shows me the last incoming or outgoing number instead of telling me UNKNOWN..
    I think I've solved the problem.
    Tomorrow I'll post a new Cinergy 600 implementation beta release also with the PhoCo issue fixed... stay tuned
  4. #454
    Apr 2006
    Greece
    robby you rock!!!
  5. #455
    Aug 2005
    Italy
    Your bug fix is available here
  6. #456
    Apr 2006
    Greece
    Quote Originally Posted by Robby BMW View Post
    thanks robby, haven't tried it yet... i will in the next few days.. good work
  7. #457
    Apr 2006
    Greece
    I am very glad to inform you that Everything is working OOOOOOKKKKKK!!!!
  8. #458
    Aug 2005
    Italy
    Nice to read that
  9. #459
    Apr 2006
    Greece
    it seems that i am having trouble with hibernation.. but it is does not happen always..it is sort of random..i haven't figured out what is going on yet, but i will give it a few more days of testing..
    In the menawhile robby can you explain me how exactly RR handles the connection to the phone and the TCP conection to phoco...(i mean when does it connect, when does it disconnect, how often does it try to reconnect..etc OR does phoco handle the connection to the phone part??) it would help me to narrow down the problem..
    thanks again..
    EDIT: and a question(i should be asking zorro..but there it is) does phoco stop trying to connect after x times when exitifinitfails = false ???..
    for example.. when i start my carpc..and phoco connects..(ok untill now) then i get out of the car and enter a supermarket (and bluetooth connecion is lost due to distance) does phoco try to reconnect??....(how many times??) and if i come back to the car after 10 minutes will it reconnect??..(from my experience untill now it will not..i would have to close RR and restar it (in order to restart phoco)...
    And one more thing.. before suspending Does RR send a "ONSUSPEND","CLOSE_PHOCO"
    "ONRESUME","RESUME_PHOCO" by default, or does it just disconnect phoco..? i guess closing it will solve many things.. or do i have to add it manually in exectbl.ini
  10. #460
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Thumbs down
    Nomader and Robby
    I tried to make a shortcut (rt click on desktop/new/shortcut...added -remotenodesign in the target line), ran rrconfig again to point to phoco directories, open Phoco first, it's not in trial mode because it launched as normal, open rr but still nothing shows.
    I see phoco in the background, bluetooth in the system tray but it not remoting controlling rr.
    I went back to phoco in the remote section and 17015 is the port and I tried both Server and client but it did not make a difference.
    I posted a message on phoco forum to Zoran to check as well.
    I read somewhere about Firewall so I opened my port for 17015 for incoming and outgoing on TCP.
    How else does the remote feature work with phoco and rr?
    What other setting in Phoco besides the remote section to setup?
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
