Page 47 of 55 FirstFirst ... 37383940414243444546474849505152535455 LastLast
Results 461 to 470 of 545
Thread: Release new phoco integration preview
  1. #461
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok do me a favour and tell me..
    1. have you bought phoco or not.. (thats the way to know if it is in trial)
    2. did you copy and paste what i told you(don't write it yourself, you might be forgetting a space or something)
    "C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe" -remotenodesign
    3. the remote control should be "server"
    4. forget about RR for the moment.. double click on the shortcut on your desktop.. what happens? if you have not registered (bought) phoco a window asking you to try/buy pops up..if you have registered it an icon in the system tray appears (phoco icon) and nothing else...
    5. then run RR
    6. Again if you have registered phoco..there is nooooo need for the shortcut..RR opens phoco in remotenodesign mode (that is if you have (and should) select "remotenodesign" option in rrconfig..
    7. thats it really..
  2. #462
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    1. Yes...I purchased Phoco and have the license key. NO JOKE!
    2. i created a shortcut - rt click on desktop/choose new/shortcut/ click browse to go to phoco directory "C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe" and added -remotenodesign
    3. I have 'server' as the name
    4. The phoco icon appears in system try (like I stated before)
    5. Did
    6. I chosed that option (unchecked and rechecked it to be sure)
  3. #463
    Apr 2006
    Greece
    navputer.. sorry for asking again..but i need to understand..you are saying now that you got phoco working in remote mode or not??
    1. phoco on remote mode : you double click on the "special shortcut" nothing opens, just phocos icon in the tray
    2. normal mode: you double click on the standard phoco shortcut phoco graphical interface opens..
    which of the two??
  4. #464
    Jan 2007
    DFW Area
    No offense at all....I appreciate you helping me on this.
    1. Right, I double click on the special shortcut icon, I see phoco in the system tray but i see phonecontrol graphic window on left and I click that and I see a faint veiw of phone control
  5. #465
    Jan 2007
    DFW Area
    I do not have Phoco working in remote mode.
    1. I doubleclick on special shortcut and I just see phocos icon in the system tray. I do see a phoco window on the left, i click it and i see a faint view of phoco buttons.
  6. #466
    Apr 2006
    Greece
    you should not see anythging at all....
    can you give me a screenshot??
  7. #467
    Jan 2007
    DFW Area
    Sorry, I am at work right now replying to your messages. .
    I will post a screenshot tonight though.
    Anything else I should add or look for or post?
  8. #468
    Jan 2007
    DFW Area
    Here are my screenshots.
    1. Notice the first capture with phonecontrol small window on bottom.
    2. Notice the second capture after I double-click it. You see a faint view of phoco.
    3. Is this a setting in phoco I need to change?
  9. #469
    Apr 2006
    Greece
    ok i unserstand now..
    you are not doing the shortcut part i told you correctly.
    1. open "c:\program files\phoneControl" in windows explorer and locate "PhoneCtl.NET.exe"
    2. Drag the file to your desktop using your RIGHT mouse button and release when you are on your desktop..a menu appears. select "create a shortcut"
    3. right click on the shortcut on your desktop and select properties.
    4. COPY/PASTE the text i told you on the posts above into the TARGET (not into the "start in")
    5. plz copy paste it and don't write it yourself.
    EDIT: by the way i did that mistake myself... it took me 2 hours to figure it out.. phonecontrol opens this way because it cannot find its skin files..as it needs to be opened from its own folder..(someone correct me if i am wrong)
  10. #470
    Jan 2007
    DFW Area
    1. I did
    2. I did
    3. I did and copied your information from the previous post
    There is a setting in phoco that I had to change as well. If you goto Extended Configurator - Use Taskbar. I set that to false. If you set it to true, you will see the icon.
    Since turning off that feature and following your instructions above. The only thing I see now is Phoco icon in the system tray. So, I went back to rr and to phone control but still no contacts, etc.
    Also, I want to mention that this has worked before with no problems. When I performed the latest update that's when the problem starting occurring. I will post my latest phoco and rr log files.
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 08:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 06:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 10:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 01:56 AM
