Instead of quoting the above posts,
1.. Yes the Microphone is activated anytime there is a call in progress, whether inbound or outbound.Then once the call is over the microphone is off. This happens with the USB cable connected and NO Bluetooth.
2.. Some of Motorola phones have a setup to auto-answer when they are flipped open, this can cause problems with RR/Phoco initializing or resetting after a call. Setting it to not answer when flipped open will help somewhat.
Now,
Testing with only a USB cable to the phone and NO bluetooth dongle or bluetooth devices active.
I tested this every time from a fresh boot up.
Testing in Phoco only, there are no problems, it works. Checking the device manager, etc, everything looks fine.
With RR activated and calling Phoco remotely, I can get either one of these two errors in a popup window.
#1.. Setup Error:Failed to load Resourcefile, Please check setup.
#2.. PhoneControl.Net Error: Opening com port failed
If I close RR then goto Phoco, it works fine. Sometimes when I load RR after this it will work with Phoco???
Now, testing with Bluetooth only and reconfiguring the setup options in PhoneControl using the Extended Configurator for Bluetooth com port address! No USB cable connected.
Again from a fresh boot up and going into RR.
Errors #1 and #2 can be repeated with bluetooth as the communications link.
Going to Phoco as a standalone, no problems.
Resolved the Work and Home contacts from not working.
Renamed them in my cell phone and then did a reload in RR's phoco skin page to update the addressbook. After that, went back in the cell phone and renamed them back to Work, Home respectively. The CFX skin doesn't have a contacts popup window, it is on the phoco skin page and scrolling and highlighting will make that entry activate. Since all the other contacts would work but these two, then I can't tell you what caused that one.
Still testing.
LinkBack URL
About LinkBacks
