Page 51 of 55 FirstFirst ... 414243444546474849505152535455 LastLast
Results 501 to 510 of 545
Thread: Release new phoco integration preview
  1. #501
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Is it a registered version, because otherwise a register box comes up which needs to be clicked away and if you are using -nodesign it stays hidden so you can't click it away
  2. #502
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    yes i am registered. i bought phoco sometime in 2005 but never really got it working the way i wanted with the razr but since i have a phone (cingular 8125) that actually does more than one bt connection at a time i wanted to try again.
    also if anyone is interested circuit city has the logitech quickcall usb speakerphone for $9.99 after a $70 mail in rebate. supposedly the right sound technology cancels echos. i picked one up last night to try. i don't know about the sound quality yet but my first impression is that the thing is huge. if the sound quality is good, the next step is to hack it up to make it fit into something smaller.
    http://www.circuitcity.com/ccd/Searc...&go.x=0&go.y=0
    Quote Originally Posted by Enforcer View Post
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  3. #503
    kuo
    kuo is offline
    Jun 2003
    Greensboro, NC
    i did some testing on the wife's carputer install and there seems to be a difference in the way phoco starts when it is started using rr with -remotenodesign checked and when it is started on it's own via shortcut (with or without -remote). when phoco is started by rr, the phone doesn't get initialized but if i start phoco using a shortcut, then it does. for now, i have a shortcut to phoco in my startup folder using the -remotenodesign flag and start up rr with an autoitscript that waits for phoco to start then starts rr. this setup is working for me so far.
    a side note on the logitech quickcall. the echo canceling seems to work pretty well. the size issue was solved with a dremel rotary tool. after i removed the speaker and desoldered the 2 pcb boards, i was able to fit everything into my sunglasses holder which is too small to hold anything but flat folding sunglasses. not a bad investment for $10.
  4. #504
    May 2007
    Israel
    Help!!!
    The phone control 1.77 and the rr seems to save diffrent type of phone book.
    that is the road runner phonebook
    - <AddressBook>
    - <AddressBookEntry>
    <Name>12341234</Name>
    <PhoneHome>12341234</PhoneHome>
    <PhoneWork>123412341</PhoneWork>
    <PhoneMobil />
    <Fax />
    <PhoneOther />
    <E-Mail />
    <Street />
    <City />
    <ZIP />
    <Country />
    </AddressBookEntry>
    this is the phone control :
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <PhoneBook>
    <PhoneBookEntry>
    <Name>asdf sdf</Name>
    <Number>0567880159</Number>
    <Type>/O</Type>
    </PhoneBookEntry>
    how can i make these the same? change settings in phone control or on road runner or where.....?
  5. #505
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    plz explain me what exactly r u trying to do? RR has its own phone book, yes it actually imports phocos phone book, r u using the phones phonebook or imported from outlook etc.?
  6. #506
    May 2007
    Israel
    Im trying to make the phonebook work with rr
    If i choose to use the phone phonebook , then in rr there are no phones even though the phonebook directory is defined the same as in phone control.
    the rr doesnt read the phonebook.
    then i noticed that the rr internal phonebook is saved in an xml file that is in diffrent layout then the phonecontrol layout.
    i manually changed the tags to fit and it worked.
    how can it be automatic ?
    how do u integrate the phoco pb with rr pb ?
  7. #507
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    oh ok .. zorro changed the xml format... eh well that should be doable.. just need to change rr's source a bit
    Live mp3Car Facebook Chat
  8. #508
    Aug 2003
    i am having the same issue. RR is unable to retrieve my phones internal phonebook even tho I am able to view it when I run phonecontrol externally. I am using the latest releases of both phoco and rr (1.77 and 4/11/07). Has anyone figured out how to get rr to load the phones internal phonebook?
  9. #509
    Aug 2003
    i spoke to zorro about this issue of not being able to access the phone contacts in roadrunner. In regard to the earlier post by Arikdpc about the changed formats, that is not true. zorro said that as long as the setting for contacts is listed as phone in rr.ini, there should be no difference in phone book settings and format.
    So I am still stuck here. I can read my phones contacts normally in phoco when i run it standalone, but when i get into RR, it cannot pull up my phone contacts at all. I hope someone knows why this is happening. I am using the latest versions of RR and phoco as I said before.
  10. #510
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Installation files
    Hi I have got the BETA version from post 1.... to install Phco..
    In the last line for isntallation direstions you ask to copy BOTH files...
    While the RAR file that i have downloaded has ONLY 1 file.... RR.exe
    can u pls look into this
    thanks
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
