Page 53 of 55 FirstFirst ... 343444546474849505152535455 LastLast
Results 521 to 530 of 545
Thread: Release new phoco integration preview
  1. #521
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by ajamils View Post
    It's not a problem with the skin because I'm running a stand alone version.
    if this isnt a problem with road runner you need to post your issue in the phonecontrol section.. better yet post it on the forum at phoco.net. This thread was meant to be about Phoco's integration in RR.
    Live mp3Car Facebook Chat
  2. #522
    Constant Bitrate digeratix's Avatar
    Sep 2007
    Quote Originally Posted by Robby BMW View Post
    Your solutios is HSPDisconnect !!!
    Try this little AutoIt script that I've create to auto close the "btstackserver popup alert" that rise when you try to enter in hibernation mode with the BT Headset connected.
    Copy this script in your hard-disk and make a link in your windows startup folder, in order to get it auto running at windows startup.
    Let me know if it will solve your problem...
    If your popup window title is " ServerStackBT " ==> HSPDisconnect 1
    If your popup window title is " BTStackServer " ==> HSPDisconnect 2
    Can you show the code you wrote to make BTStackServer dismiss itself?
    I was going to try and do something like that with AutoIT, but I am clueless as to how.
    I just downloaded the program last night.
    Im so glad that you made the exe, its exactly what I needed.
  3. #523
    Jan 2007
    Greece
    I can't also see the phone's phonebook from inside RR.
    If phoco is running standalone, I see them correctly...
    Has anyone figured it out?
    PS: Yes, i've read all the 35 pages of this topic :P
  4. #524
    Oct 2006
    Raleigh
    Verizon V3C phone
    Ok guys here's my story with a motorola Verizon V3C phone
    Setup:
    Windows XP SP2
    Motorola USB drivers: Motorola_EU_Driver_Installation_v2.6.2.msi
    Widcomm Drivers: Widcomm 5.0.1.801 bluetooth drivers
    Latest version of RR: 2007/11/04
    PHOCO Latest version 1.7
    The phone has to be open all the time.
    PHOCO Standalone:
    Install Motorola USB drivers
    Install the phone as a modem (and get the port number)
    Pair Phone
    After running the PHOCO install, run the wizard, it will find the phone but if wont find a port.
    Run the PHOCO Extended configurator and change the port number under communications-->Motorola V710 to match the port of the motorola modem
    In Extended configurator go to communications-->Motorola V710-->Usemode and change the on and off attributes to +MODE=2 (this will stop the phone from beeping evry 10 secs or so)
    When making a phone call all works well, but when receiving a call after I press the green button the audio gateway connects but the red button goes gray, when I need to hang up I have to press the headphones on top so it disconnects the audio gateway.
    In RR making calls is great, but receiving them has the same issue as above I dont think it something to do with RR because the beahaivour is seen in PHOCO and the V3C phones.
    Does anybody know how to make an icon in RR that would duplicate the same fucntion of the headphones in PHOCO?
  5. #525
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    Quote Originally Posted by agiorgitis View Post
    It sounds like your phone uses a different encoding than UTF-8 for the phonebooks.
    Try to change the encoding in RR to UTF-16.
    _______________________________________
    Car installation 95% [■■■■■■■■■■■■■■■■■■■]
    Current project: Parking sensor USB interface
  6. #526
    Oct 2006
    Raleigh
    Quote Originally Posted by Charly View Post
    Setup:
    Windows XP SP2
    PHOCO Standalone:
    Pair Phone
    Update:
    I found what was making the incall button go grey
    11/27/2007 8:23:15 PM >AT+CLCC
    11/27/2007 8:23:15 PM <
    ERROR
    I changed CLCC to false and disconnectAfterCall to False
    all is working now, I also found a little program that removes all the Motorola drivers that your computer might have and installs the proper ones automatically, if someone needs it send a PM.
  7. #527
    Jan 2007
    Greece
    Nothing...
    I tryied all the encodings but still nothing.
    It must be sth else.
  8. #528
    Jan 2007
    Greece
    Phoco stopped being updated, support for users until March...
    Too bad
  9. #529
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    Phonecontrol in DigitalFX
    I unfortunately purchased Phonecontrol and registered in December. I have it working outside of RoadRunner and DigitalFX skin.
    I have seen posts that say replace Freefone "Phoco" in menu.skin. That works to the extent the Phonecontrol skin comes up. It does not dial or anything else.
    So for those of you who have it working under RoadRunner, please share your exact entry in menu.skin or where ever it resides.
    TIA, mnwcsult
  10. #530
    Wox
    Wox is offline
    Mar 2004
    Hello @ all
    Sorry for my first and stupid message, but i donīt find the download link for the Phcco program? Or for the latest rr.exe with phoco ? Please help me, and sorry for my bad english
    Sincerely
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
