@ tbird, warningslo, liquid smoke and wfs
It sounds like a problem with the .NET Framework that occurs under some circumstances on some machines. You may try to install or reinstal .NET Framework 1.1 Service Pack 3.
Printable View
Ho già notato questo problema e sarà risolto nella prossima versione.Quote:
Originally Posted by Mr.Fabio
Grazie per la segnalazione.
I've already noticed this problem and it will be resolved in the next version.
Thanks for the feedback.
Of course, this is the best setting to use the audio gateway, but however with some phones it doesn't work properly and the only way to use the audio gateway is with a permanent connection.Quote:
Originally Posted by teo256
i dont think this has anything to do with .net (at least not on my machine). Ive never had phoco startup issues like this till this release (current RR release) and running phoco standalone i never have any issues at all. If i go back to an older RR release i dont have this issue either.Quote:
Originally Posted by Robby BMW
specs
Dell XPS2 laptop
2.0GHz Pentium M
2GB Ram
nvidia 7800ultra 256mb
Bluetooth 2.0EDR widcomm 5.0.1.802
Sony Erricson T610 (the same phone phoco was originaly coded to support)
Obviously this isnt my carputer :)
honestly at this point im really starting to think there are issues with PhoCo when it is launched in the remote state. Centrafuse users seem to have some of the same issues in the past (and present) with the embeded phoco. Maybe somebody should drop zorro a line and see if he can iron out all these issues.
It's a reasonable doubt, really the PhoCo's Remot Control has many problems,Quote:
Originally Posted by liquid_smoke
I have had to write a lot of code in RR in order to prevent some PhoCo issues.
I'll give a look to see what I can do to fix this issue too.
This works perfectly, thanks!Quote:
Hi Robby,Quote:
Im still using v1.5.
Is the option ExitIfInitFails also available for this version?
I looked real hard but I cant find it.
And I have to say. Im really greatful for all the work you put in this.
My biggest pain was getting phoco to work 100% in RR.
Could you give me your thought over the following problem Im dealing with.
I copied one of the .PST presets, renamed it PHOCO.PST, put it in the RR folder with the rest of the .PST files. In the MIXER skin (ALPINE) I removed the setting "WINAMP" before I copied the .PST.
Still, I cant get RR to switch to the PHOCO.PST presets when it comes to the main volume, so I always get voice over a muted line.
Do you know how I can solve this?
Again, thanks for all your effort
On the PHOCO.PST file;
The previous versions of RR and phoco had a general setting entry into the phoco.ini file for pathing.
The entry was;
#General Settings
Mixerpreset_call=c:\Program Files\RoadRunner
I've entered this into the phoco and still testing with different versions of Phoco and RR.
With Phoco 1.5 and RR 01/15/06 this is working along with the remote initialization of phoco from RR and no problems.
Plan to test each revision of RR with both Phoco 1.5 and 1.6B
I'm afraid, but this option is not available in the 1.5 version however the problem would not have to exist because that version would have to try to reconnect the phone itself by defalt. Try to start PhoCo with the phone out of the bluetooth range, then move the phone in the bluetooth range and wait to see if the connesione will be established (it could need a lot of time).Quote:
Originally Posted by peijffertje
With respect to the other problem, I've noticed a little issue in the source code, but it will be solved in the next release.
Ahhh. So that means I can stop copying, renaming and testing the phoco.pst.Quote:
I look forward to this new release. For me, phoco would finally be 100 % working in RR. (any idea on when it will be released?)
Again, thank you very much for all the effort!
