Page 7 of 55 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 545
Thread: Release new phoco integration preview
  1. #61
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    Italy
    @ tbird, warningslo, liquid smoke and wfs
    It sounds like a problem with the .NET Framework that occurs under some circumstances on some machines. You may try to install or reinstal .NET Framework 1.1 Service Pack 3.
  2. #62
    Aug 2005
    Italy
    Quote Originally Posted by Mr.Fabio
    As the title said...
    I found this little bug in the new updated version, 04-08
    When a call is incoming RR change the mixer preset to phoco, but when the call hangs the previous preset does not resume...
    Anyway,
    Thankx for your big effort in development phoco x RR
    Grazie Robby
    Ho già notato questo problema e sarà risolto nella prossima versione.
    Grazie per la segnalazione.
    I've already noticed this problem and it will be resolved in the next version.
    Thanks for the feedback.
  3. #63
    Aug 2005
    Italy
    Quote Originally Posted by teo256
    is it ok if RR start the audio-gateway only when there is a call? Because if i don't use this integration, the audio-gateway is always on, if i use this release the audio-gateway switch on only when there is a call.
    Of course, this is the best setting to use the audio gateway, but however with some phones it doesn't work properly and the only way to use the audio gateway is with a permanent connection.
  4. #64
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by Robby BMW
    i dont think this has anything to do with .net (at least not on my machine). Ive never had phoco startup issues like this till this release (current RR release) and running phoco standalone i never have any issues at all. If i go back to an older RR release i dont have this issue either.
    specs
    Dell XPS2 laptop
    2.0GHz Pentium M
    2GB Ram
    nvidia 7800ultra 256mb
    Bluetooth 2.0EDR widcomm 5.0.1.802
    Sony Erricson T610 (the same phone phoco was originaly coded to support)
    Obviously this isnt my carputer
    honestly at this point im really starting to think there are issues with PhoCo when it is launched in the remote state. Centrafuse users seem to have some of the same issues in the past (and present) with the embeded phoco. Maybe somebody should drop zorro a line and see if he can iron out all these issues.
    beer replenishment fund
    mp3car live search
  5. #65
    Aug 2005
    Italy
    Quote Originally Posted by liquid_smoke
    ...honestly at this point im really starting to think there are issues with PhoCo when it is launched in the remote state. Centrafuse users seem to have some of the same issues in the past (and present) with the embeded phoco. Maybe somebody should drop zorro a line and see if he can iron out all these issues.
    It's a reasonable doubt, really the PhoCo's Remot Control has many problems,
    I have had to write a lot of code in RR in order to prevent some PhoCo issues.
    I'll give a look to see what I can do to fix this issue too.
  6. #66
    Dec 2004
    PhoCo tries to reconnect the phone every 60 seconds, but by default it exits if the first attempt fails. You can change the option "ExitIfInitFails" to False with the Extended Configurator in order to solve this problem.
    This works perfectly, thanks!
  7. #67
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    Hi Robby,
    Im still using v1.5.
    Is the option ExitIfInitFails also available for this version?
    I looked real hard but I cant find it.
    And I have to say. Im really greatful for all the work you put in this.
    My biggest pain was getting phoco to work 100% in RR.
    Could you give me your thought over the following problem Im dealing with.
    I copied one of the .PST presets, renamed it PHOCO.PST, put it in the RR folder with the rest of the .PST files. In the MIXER skin (ALPINE) I removed the setting "WINAMP" before I copied the .PST.
    Still, I cant get RR to switch to the PHOCO.PST presets when it comes to the main volume, so I always get voice over a muted line.
    Do you know how I can solve this?
    Again, thanks for all your effort
  8. #68
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Arkansas
    On the PHOCO.PST file;
    The previous versions of RR and phoco had a general setting entry into the phoco.ini file for pathing.
    The entry was;
    #General Settings
    Mixerpreset_call=c:\Program Files\RoadRunner
    I've entered this into the phoco and still testing with different versions of Phoco and RR.
    With Phoco 1.5 and RR 01/15/06 this is working along with the remote initialization of phoco from RR and no problems.
    Plan to test each revision of RR with both Phoco 1.5 and 1.6B
  9. #69
    Aug 2005
    Italy
    Quote Originally Posted by peijffertje
    Hi Robby,
    I'm afraid, but this option is not available in the 1.5 version however the problem would not have to exist because that version would have to try to reconnect the phone itself by defalt. Try to start PhoCo with the phone out of the bluetooth range, then move the phone in the bluetooth range and wait to see if the connesione will be established (it could need a lot of time).
    With respect to the other problem, I've noticed a little issue in the source code, but it will be solved in the next release.
  10. #70
    Nov 2005
    Netherlands
    Ahhh. So that means I can stop copying, renaming and testing the phoco.pst.
    I look forward to this new release. For me, phoco would finally be 100 % working in RR. (any idea on when it will be released?)
    Again, thank you very much for all the effort!
  1. Software Review: PhoneControl.NET
    By zorro in forum The Review Palace
    Last Post: 11-20-2006, 09:01 AM
  2. phoco intergration, latest ver issues
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 04-02-2006, 07:14 AM
  3. Phoco Integration
    By Cheekz185 in forum Road Runner
    Last Post: 01-03-2006, 11:42 AM
  4. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  5. A little Idea on Phoco integration
    By Mr.Fabio in forum Road Runner
    Last Post: 05-25-2005, 02:56 AM
