havent tested a whole lot yet, but so far the latest version seems to work ok.
not having any of the issues peijffertje is having (prob skin related).
will test more later tonite
Printable View
Smoke, your not having the problem with it only connecting like 20% of the time anymore?
nope.Quote:
Originally Posted by tbird2340
i did get one error once about it not finding the port or something, i clicked ok and it still connected to phoco where before it wouldnt. ill do some more testing today and give more solid findings.
What'd you do?? Is there a new version I missed or something? I thought you were having the same problems as me..
In this thread at the end of the page; http://www.mp3car.com/vbulletin/show...t=73444&page=5
Is a beta release/Update.
Oh snap.. How'd I miss this? Thanks!
How thru rr do you tell the phone to disconnect from the audio gateway? i can use the gateway but it stays connected after the call and never gives the bt back to phoco (motorola phone).
EDIT
Nevermind, i had phoco.ini BTMANAGER true. I've changed it to false and the audio gateway isnt working at all now. my rr.ini shows as follows:
phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
phoconodesign=true
connecthsp=true
btdevicename=Motorola Phone1
contactspicturespath=C:\Program Files\Road Runner\PHOCOImages\
ringtone=C:\WINDOWS.0\Media\ringin.wav
standardphonebook=0
maxcalllistentries=100
debugmode=false
It works as it should in phoco standalone but not inside of rr. I'm using the 4/23/06 release.
ok i guess i'm a little confused and i think i know why. I was under the impression that the added features included the trick for motorola and other phones that can only have one connection... as seen in this thread by M-Ruiter.
http://www.mp3car.com/vbulletin/show...otorola+phones
if it doesnt include the command "disconnectaftercall"... no problem, but what we need then is a command that does this:
* Added the ability to disconnect the BT-Headset
Appears the command is already run when rr exits, but us motorola guys need to either add the command to our end buttons or create a button to switch inand out of handsfree.
:whs:
It'd be nice to add a Headset indicator and command in RR.
One of the good features of Phoco is to be able to save SMS templates and then use them when you need them. It is handy for when you are driving and need to send a quick msg.
I have looked at the latest support but is there a command for such a thing in the new code?
