Results 11 to 20 of 28
Thread: Online indicator help...
  1. #11
    Oct 2003
    Copenhagen, Denmark
    Sure, let me find it and make some small doc for it as well, i had it using some cmd line parameters for interval and address to ping and stuff that i probably should document.
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
  2. #12
    Oct 2003
    Copenhagen, Denmark
    Found it on my development pc at home,
    Download : http://www.boyakasha.dk/inetup.exe
    here is a "short" explanation :
    The inetup.exe utility is meant to check reachability of an ip address by using ICMP Echo/Echo Reply (PING), and on that basis create a file or delete it depending on whether or not the address responds to ping. If started with no cmd line parameters the program will just start without doing anything, you can then use the input boxes for setting it up. However you can use parameters to specify the ip address to ping, the interval at which it should ping, and what path/file should be created or deleted and if the program should start enabled or disabled.
    Params :
    inetup.exe <IP> <interval> <state> <file>
    IP : Address you want to check (ex.193.88.44.42)
    Interval : how often should it ping, in milliseconds (ex.3000)
    State : Should the program start pinging upon execute (ex.True)
    File : the path and or filename that should be created/deleted (ex.c:\connected.txt)
    Params must all be used if any of them are used at all in the order stated, and the filepath must be created already.
    Example : from Start/Run : "C:\RoadRunner\inetup.exe" 193.88.44.42 3000 True c:\download\connected.txt
  3. #13
    Jun 2005
    Michigan
    Any way to include multiple ips in the ping list, and just OR the result? Just in case the IP you choose goes down...
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
  4. #14
    May 2005
    Vienna, VA
    can we use www.google.com instead of an IP?
    Pretty sure it'll be EXTREMELY rare for Google to go down.
  5. #15
    Jun 2005
    Michigan
    With multiple IPs, do Google, Yahoo, and MSN...with that combination, them all going down pretty much means the apocalypse
  6. #16
    Oct 2003
    Copenhagen, Denmark
    i got name resolution working, so now you can get the new version, www.boyakasha.dk/inetup.exe only change i did for now is that instead of ip you put the hostname like www.google.com or www.msn.com or whatever you like.
  7. #17
    May 2005
    Vienna, VA
    Okay, I also wrote my own version using AutoIt (called AutoNetDetect). This app checks for local connection state first then verify it by pinging Google.com. If a valid connection is detected, a file will be created (default = C:\connected.txt). Otherwise, the file is deleted. You can also choose to run an app when connected (this is so you can update your weather, traffic report, etc.)
    The following parameters are configurable via AutoNetDetect.ini.
    Check Interval
    Host to Ping
    App to Run when connected
    File to Create when connected
    Attached Files Attached Files
  8. #18
    May 2005
    Vienna, VA
    Here's an update with a tray icon and small bug fix if anyone cares.
  9. #19
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    very important question about your software!!! Does it work when windows isnt the shell? net-detect doesnt :|
    Live mp3Car Facebook Chat
  10. #20
    Woodbridge, VA
    Blog Entries
    32
    i'm gonna test the ability to run out of windows shell tonight. So far this program looks good! Small request, is it possible to have connected.txt deleted upon exit of your program? Without this the computer would think it has access after a reboot right?
  1. online audio retailers
    By johnnm in forum Car Audio
    Last Post: 03-15-2006, 01:29 AM
  2. Replies: 11
    Last Post: 01-30-2006, 09:47 PM
  3. RoadRunner Webserver back online
    By Gobby in forum Road Runner
    Last Post: 11-06-2005, 10:30 AM
  4. Acrylic or ABS suppliers? Anyone know any online
    By clean customs in forum Fabrication
    Last Post: 09-18-2005, 07:39 PM
  5. Buying hardware online
    By JorisC in forum Newbie
    Last Post: 05-22-2005, 01:30 PM
