Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Online indicator help...
    Aug 2004
    Lancaster, Ohio
    I am useing the BMV2 skin and have everything just about set up the way I like it. I have all the buttons saying what I want them to when I push them, I have iGuidance embedded, I changed the location and colors of some of the text. Been working for two days getting everything just the way I want except for one thing.... I can not for the life of me get this damn online indicator to work right.
    I know it has got to be something so simple that I am overlooking it. I have been playing around with the .ini files and am getting nowhere. I do have an "online" jpg in my skin folder, I have this in my menu skin file...
    /, I, x, y, w, h, Code;INDICATORCODES
    I,30,45,150,30,"ONLINE"
    IMG,30,45,130,20,"online.jpg",on
    I01,185,455,30,35,"MUTE:b"
    The "online .jpg" does show up on my menu skin where I told it to, but it never goes away if I disable my internet connection.
    This is the last thing I need to do before my skin is finished and I can put my system in my car. Anybody...........
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Is it in a button or something
    Try this and see what happens
    I,30,45,150,30,"ONLINE:b"
    2001 S10 ZR2
    Chucks Skin - to old
    Aug 2004
    Lancaster, Ohio
    hey Chuck, I tried that and now it just flashes all the time. Its not a button. With skin editor I added an "indicator" box below my "date" box. The "img" box is inside of the indicator box. Do I need to modify any other files? Or only the menu file. I do have the lastest version of RR. Did an update with the automatic updater.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    the online indicator isnt perfect and it doesnt test for an "internet" connection.... only for a network connection. That code above is the same i use (in different area of course) and mine works as it should. You did add the indicator "image" to your "on" skin right?
    Live mp3Car Facebook Chat
    Aug 2004
    Lancaster, Ohio
    Sonic, Yea I have indicator image in my skin. I got it working now. Thanks guys!!. It was a stupid mistake on my part. I am testing it on my home pc and I diabled my cable modem to test it. But as you said it checks for network connection!! I was technically still connected, just not to the internet. Once I pulled my network cable out, the "online" image does go away and then return when i plug it back in. Once again, Thanks guys, I knew it was something simple.......
    Jun 2005
    Michigan
    Could you post your indicator code? Using my wireless card, turning it on makes the online light appear after a little while, but it never shuts off until I restart RR if I then kill the wireless.
    MII-12000 / Ampie / Lilliput 7" / BU-355 / PicoPSU / uSDC
    Currently: Enjoying the setup, but always contemplating my next move...
    Woodbridge, VA
    Blog Entries
    32
    make sure ur indicator is set to blink (online:B) else it wont shut off.
    Jun 2005
    Michigan
    Even when its not over a button? Will this ever be fixed? Blinking would get very annoying...
    Oct 2003
    Copenhagen, Denmark
    i did a little util that pings something (isp dns in my case) every few seconds, and then creates a file if connected and deletes it if the connection is lost. This can be used in conjunction with the exists indicator that can check for a files existance. This will give you a real world idea of whether or not you are actually connected to the internet
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hey _dopehead_, if you can, I'd like to include that "ping" app in RR's page .. I did try the Ping method in RR but it was just hogging up too much with VB's pseudo-multi-tasking.. so I cut it out.. it's best to have a separate application just to monitor it, like you did..
    Ride Runner RR's Myspace
  1. online audio retailers
    By johnnm in forum Car Audio
    Last Post: 03-15-2006, 01:29 AM
  2. Replies: 11
    Last Post: 01-30-2006, 09:47 PM
  3. RoadRunner Webserver back online
    By Gobby in forum Road Runner
    Last Post: 11-06-2005, 10:30 AM
  4. Acrylic or ABS suppliers? Anyone know any online
    By clean customs in forum Fabrication
    Last Post: 09-18-2005, 07:39 PM
  5. Buying hardware online
    By JorisC in forum Newbie
    Last Post: 05-22-2005, 01:30 PM
