Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: XM works in Timetrax, not RR
    Dec 2004
    I have an XM commander box with a DIY serial cable connected to the COM2 header on a VIA MII. When I open TimeTrax, everything works perfectly. When I open up XM inside RR, it doesn't work. I am using the iDrive skin.
    In the RRconfig, I have XM Serial Port set to "2", and have played around with the 'Use Line-In Plugin' and 'XMPCR mode' with no luck. Has anyone else experienced this problem and what can be done to fix it? Everyone once in awhile, perhaps after a reboot, XM will magically in RR, but it usually doesn't.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've never heard of an XM Commander box .. I only know of XMPCR and XMD1000.. so you may be referring to one of the two ... if you have a XMPCR (the USB version of the XM tuner), you need to check the XMPCR mode option in RRConfig or it won't work, if you have the XMD1000 then you need to leave that unchecked.. now, if you have some 3rd version I don't know about.. most likely it will not work.
    Ride Runner RR's Myspace
    Dec 2004
    Quote Originally Posted by guino
    I'm sorry, it is the XMD1000 which I am powering through the 12V/ACC/GND plug on the box itself instead of power through the serial cable.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Now, you're saying it works with TimeTrax.. is this plugged through the TimeTrax Dongle or directly ? I'd suggest you try a 3rd application like FrodoXM, etc.. I'm assuming you are closing out of TimeTrax before launching RR.
    Dec 2004
    What is the Timetrax dongle? I have a cable running from the XMD1000 to the COM2 serial header on the VIA MII mobo.
    Nov 2004
    St Louis
    I run Commanders in my cars and they are just high end XMD1000 s with an external control head and FM antenna slicer. The XM model # is XM-RVR-FM-001. It is exactly the same size and function as the XMD1000 with the addition of an internal FM transmitter and separate power connector.Because the commander's control head uses the com port they had to add a separate power source connector. I like it cause when my tablet isn't in the car, I can still control/listen to XM using the commander controller and my headunit.
    One drawback I haven't been able to resolve is that it will only display 16 characters as opposed to the 32 available through the XMD.
    Quote Originally Posted by bruha
    What is the Timetrax dongle? I have a cable running from the XMD1000 to the COM2 serial header on the VIA MII mobo..
    I have both and believe me the serial setup is much better. The serial solution has power and signal in the connector - period - DONE. The Timetrax interface adds cables, connectors, power, and requires additional USB drivers. I thought it would be a cleaner solution since it was USB, but as far as I'm concerned its strictly a last resort for those people with no more serial ports available. And way overpriced at $80.
    Newbie hank_kls65's Avatar
    Sep 2005
    Union City, PA
    XM Commander Question
    Quote Originally Posted by GizmoQ View Post
    GizmoQ,
    On your Xm commander, are you running that with RR and if so, are you having any luck doing so. I am trying to use the same thing but I can only get it to work if I setup to not use xmpcr start/exit rr, then set for xmpcr, start/exit rr, then finally start rr. Strange, but that is the only way my xm works.
    Let me know what you are doing.
    Hank
    2005 Titan SE - TiPuter
    Commell LV-677 CoreDuo
    200G HD / 1G RAM
    Lilliput 629GL-70P
    Phoco/XMD1000/WinTv/
    BU-353 GPS/WiFi/Bluetooth
    DSATX
    Dec 2004
    Guino, I found that if I open Pyro's XMTest program and then close it, it initializes the XM Direct and the XM commander so they both work in RR. Attached is a log of the data over COM2,
    [29/10/2006 19:08:58] - Open COM2 port (C:\WINDOWS\system32\ntvdm.exe)
    [29/10/2006 19:09:01] - Written data
    5a a5 00 03 74 00 01 ed ed 5a a5 00 04 74 02 01
    01 ed ed 5a a5 00 03 74 0b 00 ed ed
    [29/10/2006 19:09:03] - Read data
    5a a5 00 04 e4 01 00 80 02 68 5a a5 00 04 e4 01
    00 82 02 6a
    [29/10/2006 19:09:07] - Written data
    5a a5 00 05 00 10 10 10 01 ed ed 5a a5 00 02 00
    ed ed 5a a5 00 06 10 02 01 00 00 01 ed ed
    [29/10/2006 19:09:10] - Read data
    5a a5 00 1b 80 01 00 00 33 11 06 20 03 05 00 00
    00 09 06 22 20 04 08 52 36 44 31 36 30 52 5a 04
    79 5a a5 00 01 e0 01 e0 5a a5 00 06 90 01 00 01
    01 00 01 98
    [29/10/2006 19:09:17] - Close port
    Is it possible to modify RR so it sends the same commands that the XMTest program sends to the unit?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you make a log using portmon (www.sysinternals.com) I can try to work it out -- but without the unit to test it, it's not going to be simple. IF you do make the log, make sure it has time stamps and that it is showing the data in Hex
    Dec 2004
    Quote Originally Posted by guino View Post
    What is the name of the monitoring tool from that website?
  1. XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer
    By Will Albers in forum General MP3Car Discussion
    Last Post: 03-27-2006, 09:49 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. XM Problem. Runtime Error 5. Please help
    By BoyNextDoor in forum RR Bug Tracker
    Last Post: 09-01-2005, 07:51 PM
  4. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
  5. XM Direct / PCR / TimeTrax - The saga continues.....
    By kingtut in forum General Hardware Discussion
    Last Post: 10-15-2004, 04:40 PM
