Page 1 of 6 123456 LastLast
Results 1 to 10 of 54
Thread: RR 04-06-06... More..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 04-06-06... More..
    In this version:
    -Added command to set button codes entirely
    -Added command to switch AVS to full screen
    -Added command to toggle mono/stereo of Cinergy and Radiator supported FM tuners
    -Added commands to set label and button codes by ID
    -Added commands to set current favorites list directly (XM/SIRIUS)
    -Added commands to create/manage variables
    -Added Car2PC interface support (
    -Added support to use INI Paths and Window Names in skin commands
    -Added support to set variables with label code information
    -Added support to use variables in label codes and auto-switch label codes
    -Added support to set variables with data entered on OSK/NumOSK
    -Added support to save/load persistent variables to RR.INI
    -Added support to use "include" files on screen definitions
    -Added support to save XM startup channel on separate file (when xmcache.ini is read-only)
    -Added support for foreign text in Phone Book List
    -Added support for 3 Extra Application OSK screens
    -Added prevention on serial port usage while hibernating/resuming (Thanks Arathranar)
    -Added History Browse support
    -Added Improvements to Phoco Support (Thanks to Robby_BMW)
    -Improved AlbumArt label code to provide the path for XM/SIRIUS Art
    -Improved Skipto for use in playlist and phone book list
    -Improved Volume Control with Custom Volume Adjustments
    -Improved the standard RRConfig -- (Thanks to Mr_Wizard)
    -Fixed Memory leak issue with gestures feature
    -Fixed Album Art label code in Audio and Video Browsers
    -Fixed Issue with Internationalization Support
    -Fixed Issue with ExecTBL when executing multiple comands at last definition
    -Fixed Issue with LoadImg Command in some layers when scaling skins
    -Updated XM Art line up (Thanks to Chuck)
    -The Custom Volume settings can be set in VolTable.INI (No need to mess with it if you are satisfied with the current volume control) -- Custom adjustments are provided, but because of the nature of this feature, it's not possible to always "round" the volumes to even numbers.
    -Everything else you need to know about the above is either in Readme.txt or Skin Commands.txt
    There's always more to come.. enjoy it for now,
    Ride Runner RR's Myspace
    FLAC alti's Avatar
    EDIT: wow, 38,000 downloads not including the mirror?
    Thanks for a great program!
    My Install
    CFiG v1
    iGuidance Plugin for CF
    Working shell for a CarPC
    StopWatch plugin remade for centrafuse RC1
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
    Jul 2005
    Newport News, VA
    @guino RE: history browse
    It seems that you need to tell it what drive to start from initially, else it starts from rr dir. Working great though. Many thanx.
    Athlon XP 1900+, FIC AT31 Radeon IGP320, 256MB PC2100, Toshiba/IBM 7.2K 180GB HD,
    Sony XA-300 USB Audio -> Sony CDA-M600 HU, Integrated TV-Out -> Lilliput 7" Widescreen TV (CRAP),
    Vector 700 Watt Inverter, USB Keypad Control, Windows XP SP2, RoadRunner
    Constant Bitrate KB5WID's Avatar
    Apr 2005
    Frisco, TX
    Something to think about for the next release:
    XMRadio is in the process of changing and adding multiple channels.
    If It's Called Tourist Season, Why Can't We Hunt Them?
    I Just Do What the Voices Inside My Head Tell Me to Do.
    The Definition of an Upgrade: Take old bugs out, put new ones in.
    Texas DOS: Y'all reckon? (Yep/Nope)
    Maximum Bitrate Robby BMW's Avatar
    Aug 2005
    If someone are interested in the new features of PhoCo integration, I've posted all the informations in this post
    Jun 2004
    Just tryed it and it works great....when you close RR it close PhoneControl but it does not close headset and i can not hibernate......just phonecontrol works great and this close headset connection,but integrated rr phonecontrol does not close headset(audiogateway)
    Variable Bitrate nkotch's Avatar
    Dec 2005
    guino: Just saying thanks for all your hard work. It's a great, full-featured program while still being fairly easy enough for a non-programmer like me to mess/play with, keep it up!
    '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
    2006 Chevy Equinox LS (Current Project)
    **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    Thank you so much guino you do really a hard work, keep up the great work!
    The old setup
    The new setup
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    Creative Audigy 4
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    This is a MAJOR release... Thanks again Guino for all your help.
  1. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 10:19 AM
  2. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  3. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  4. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 08:15 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
