Results 11 to 20 of 23
Thread: Request to implement SpeedFAN
  1. #11
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Sorry for the dumb question.. How exactly do we get this implemented? I see quino included it in the latest release but do we have to change stuff in the skin file for it to work? We need to run the shoSFdata.exe?? Thanks for any help.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yes, there are new label codes like for MBM.. check it in skin commands.txt.
    Ride Runner RR's Myspace
  3. #13
    Mar 2006
    and you should run showsfdata so you know which variables map to which sensor.
  4. #14
    Nov 2005
    Missouri
    What am I missing?
    I downloaded Speedfan and it runs fine standalone.
    I copied the speedfan.exe into the RR directory.
    Used showsfdata.exe to find the sensors.
    Changed the skin to use the SFxn labels.
    As long as I have speedfan running externally it works fine (displays in the RR skins). but if speedfan is not running it does not start automatically with RR.
    Am I supposed to "load" it in RR?
    How? is there a path in the rr.ini? somewhere else?
    Also my fan speeds show as a percent rather than as RPM. I couldnt find a setting in Speedfan to change that. Is that just a function of the sensors on my PC or is it a setting I have missed?
    Thanks as always...Paul
  5. #15
    Mar 2006
    As far as I know, RR doesn't auto-load speedfan. I just leave it in my startup group so that's not an issue. Don't know about the percents for fan speed. All of mine have been rpms.
  6. #16
    Nov 2005
    Missouri
    Quote Originally Posted by sandworm
    Well I can certainly do that, but the instruction to put speedfan.exe in the RR directory doesnt make any sense.
    ...Paul
  7. #17
    Ogold007's Avatar
    May 2006
    Los Angeles
    Quote Originally Posted by deus ex machina
    OK, here's a version of Road Runner with Speedfan. All you have to do is drop the .exe in your Road Runner folder (backing up the original) and edit your skin files. When you edit your labels (which previously contained MBM codes like "MBM60" or something), you have to open the included ShowSFData.exe to find the number of each sensor. The third letter in an SF label code is "T", "V", or "F", for, obviously, temperature, voltage and fan. So the label code for a temperature might be "SFT0", for a voltage "SFV4", etc.
    Honestly, I'd be shocked if this worked for anyone besides me. But it is working well both on my main machine and my carputer. I've wanted this for a while too.
    (I also included example code if anyone wants to bother trying to figure out how to define the type properly.)
    The RAR file appears to be corrupt. I would love to have this skin, can someone host a working version of it please?
  8. #18
    Constant Bitrate deus ex machina's Avatar
    Mar 2006
    Those instructions to put the .exe in your RR folder referred to a version of RR.exe with Speedfan that I compiled before Guino incorporated it into the release. You don't need to do that now.
    This utility tells you the what your skin labels should be in RR to read Speedfan. So just replace the MBM codes with these. (You must setup SF to run on startup yourself.)
    http://www.mp3car.com/vbulletin/atta...1&d=1146584789
  9. #19
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    this is alread incorporated into the new RR version....
    just use the correct labels and make sure that speedfan is running...
    you should have more closely read the thread...guino said that it would be added, that was like 2 months ago....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  10. #20
    Mar 2006
    Oh, also make sure your fans are actually on when you're trying to get the labels. The labels are hidden until they have some kind of value (other than 0).
  1. Forum Slowness
    By Quattro in forum Mp3car Forum Suggestions/Comments
    Last Post: 10-28-2005, 05:50 PM
  2. RR GPS Command Request:
    By liquid_smoke in forum Road Runner
    Last Post: 10-16-2005, 01:49 AM
  3. Forum Really Slow
    Last Post: 05-10-2005, 03:04 PM
  4. errors on the homepage
    By alti in forum Mp3car Forum Suggestions/Comments
    Last Post: 04-14-2005, 09:26 PM
  5. About your request for Q4339-B
    By t0ffluss in forum Off Topic
    Last Post: 07-05-2002, 09:24 AM
