I also have this problem mate but it sound like you have gotton closer than me I couldnt even embed it
Hi all,
I have read that this app is not the best behaved, all the windows created are titled QWidget! However, if I set up RR to use an external app, and specify the location for Navigator, then is fires up, but leaves a blank window over the top of the actual usable window. Is there a way to close the blank window automatically ?
I really like the functionality of this product, but it is a little troublesome!
regards
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
[B]Car Computer 98%[|||||||||-]
Install Plan 100%[||||||||||]
Styling 20%[||--------]
Install 0%[----------]
I am starting to get somewhere with this. I have added a button space on the external_gps.skin, and given it the following command :
"GETFOCUS||SENDKEY;{%V};{ RIGHT};{I}"
Getfocus brings up the Navigator window. I am then trying to do ALT-V, Right arrow, I. This sequence sets/removes the input window, which will be useful when I get to use the system in the car. The sybtax however is not right, any help will be appreciated.
regards
KPJUK
Well I finally worked out most of it !
To embed Navigator 4.4, I used RRCONFIG to set the GPS to external app, and pointed it at the Navigator.exe programme. This loads up the External_gps.skin, and on that skin, I created an Application area to embed Navigator in.
When the app runs within rr, it seems to lose its way, and a blank grey window appears over the top of working Navigator window. to get rid of this I created a button area in the top left of the screen, with the attached command code.
"GETFOCUS||SENDKEY;%V{RIGHT}I%V{RIGHT}O"
Getfocus makes the working window visible, and the rest toggles the input and output panes, so it becomes a useful button for me to get the most real estate for the map.
It would be good if I could get this to work automatically, but this is a reasonable workaround to get Navigator integrated into RR.
Good luck to all you other Infomap users !
regards
KPJUK
That sounds great, although I dont really understand what you've done (not much good with teh software side).Originally Posted by kpjuk
I use Navigator aswell but the window has been bugging me for ages.
Any chance you could send me your skin and a few instructions please, would be really appreciated.
Hi OrangeBus,
I will PM the files over to you, if you want to know how they work, drop me a mail.
Good Luck
KPJUK
