Results 1 to 4 of 4
Thread: XMD 1000 Issue
    Oct 2005
    XMD 1000 Issue
    I have recently put an XMD 1000 in my vehicle with RR ...
    When I start the car, about 1 in 3 times the XM box has an issue, when it starts and it IS working however, it will work flawlessly and wonderfully until I shut off the car.
    When it's not working, usually it just starts with a ton of static, and doesn't change, you can't really even hear the music, station lists are a bit weird, etc. Then the other times it doesn't work, it will just bring up preview station and thats it.
    Now, I closed RR when it had the problems, didn't fix it, still sending static through the line in, the only fix is to unplug the power from the XMD, replug it and reboot the computer.
    It's getting it's power directly from the battery... I'm planning on switching the power over to the M2-ATX in a couple days when I have the opportunity, anyone else have any other ideas what it could be?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you should run another application (FrodoXM, etc) when the problem happens to determine if it's a software or hardware issue.. but from the details you provided seems like a hardware thing -- software issues are normally very consistent.
    Ride Runner RR's Myspace
    Jul 2006
    Connecticut
    BUMP
    Not sure if anyone else has had this issue, but I have just started to get it. I run my xmd power through the switched power in the car which has worked just fine. Every now and then, I get static when the epia comes out of standby. I can either do a full shutdown or standby again to fix the issue which leads me to believe that the xm needs to be reset.
    I just added the xmreset command into my xm skin and will test it the next time I get static. stay tuned...
    Jul 2006
    Connecticut
    Quote Originally Posted by MycoDeX
    FYI. That seemed to do the trick.
  1. BU-303 Issue
    By krazy1 in forum GPS
    Last Post: 03-10-2006, 08:14 AM
  2. Need help decoding a one wire databus...
    By Dexter in forum Hardware Development
    Last Post: 03-04-2006, 08:09 PM
  3. Boot issue
    By Slippin3 in forum Power Supplies
    Last Post: 02-07-2006, 01:19 PM
  4. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 02:16 AM
  5. Lilliput TS issue (possibly different one)
    By Willow in forum LCD/Display
    Last Post: 12-11-2004, 09:10 AM
