Results 1 to 5 of 5
Thread: Problem shutting down with RR as shell
    Apr 2006
    Hey, I have roadrunner set as my system shell, and everything runs fine. However, when I go down for reboot or shutdown, rr closes, then a few seconds later I get a message saying it can't be started because the system is going down. and then behind the message I see rr logo like it's starting again for a second or two, then the system powers off like it should... is this supposed to happen? should I worry about it? It doesn't seem to affect shutdown (other then slow it down a bit I assume)
    thanks
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Because RR is set as your shell, when it gets closed, it is automatically restarted, just like explorer. There's probably a way to fix that, but I have never bothered.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
    Apr 2006
    ok, well what would the fix be? explorer doesn't seem to restart when I shut down... :P
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try replacing the shutdown command with the windows shutdown command line tool... do a "shutdown /?" to see the parameters and use the RUN command to see if it works better. I never tried running RR as shell.
    Ride Runner RR's Myspace
    Apr 2005
    Virginia
    It shaves a few seconds off boot time to music.
    The fix is likely mentioned here somewhere.
    Try setting AutoRestartShell to a value of "0".
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
  1. Problem shutting down with frodo..
    By hotponyshoes in forum FrodoPlayer
    Last Post: 01-17-2007, 04:25 PM
  2. problem with RR 10-31-2005
    By stefanopat in forum Road Runner
    Last Post: 11-07-2005, 11:35 AM
  3. Any news about my strange problem? RR and Girder
    By slimmegane in forum Road Runner
    Last Post: 07-11-2005, 11:52 AM
  4. RR 2-27-05 Audio Browser problem
    By Curly_cat in forum RR Bug Tracker
    Last Post: 03-02-2005, 01:40 PM
  5. new windows shell & 'shell=' for win2K
    By magnetik in forum Software & Software Development
    Last Post: 04-16-2002, 08:47 PM
