Results 1 to 5 of 5
Thread: Auto gamma switching in RR
    Dec 2005
    Question Auto gamma switching in RR
    I'm quite confused about this - in several threads it mentions that built in day/night gamma switching is "under development" in RR, but the release notes of one version state that "RR now reads day/night values correctly from skin's general.ini", although I can't make it do anything with them? I then had a look at the latest source code, and there's a lot of bits from skippy76 which seem to reference auto gamma and GPS sunrise/sunset calculations, which read from certain values in rr.ini - but I can't find any documentation on this.
    So...does RR support any type of auto day/night gamma switching at the moment, and if so, what do I need to change/add to my rr.ini file to make it work? I know I could use gammacontrol, but I'm curious about what RR supports natively (if anything)?
    Dec 2005
    Any ideas - Skippy76 perhaps?
    Feb 2006
    I have the same questions.
    Assuming I don't use anything other tools but RR:
    Does it switch day/night skins on startup based on time in the skins ini?
    Does it switch day/night skins while running based on time in the skins ini?
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    if you download skippy's rr config you can use the auto gamma, however ever since daylight savings, the auto gamma has been changing 1 hour too early where i am. i've gone back to using gammacontrol by ol33l.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Dec 2005
    Do you have a copy of Skippy's RRConfig? It's not on his site anymore!
    Otherwise, can anyone give me the relevant settings to add manually into my rr.ini file?
  1. Lilliput auto - switching Video
    By HagOO in forum LCD/Display
    Last Post: 02-19-2009, 03:03 AM
  2. Auto gamma correction when the dashboard lights come on?
    By Lum in forum General Hardware Discussion
    Last Post: 11-26-2005, 12:02 AM
  3. Question about auto switching audio
    By Tangerine_Man in forum Car Audio
    Last Post: 08-28-2005, 01:58 PM
  4. Auto load FD when RR starts up
    By tolisn in forum Road Runner
    Last Post: 07-08-2005, 05:30 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
