Results 1 to 2 of 2
Thread: girder playlist setup needed thanks
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    I am using the rr gml as found in the sticky.
    Everything works great except trying to gigure out on loading playlists.
    I have all my playlists numbered 1 thru whatever.
    How do I setup girder to load playlists using the remote control.I.E. press #1 or#100 etc..then press the enter key on the remote(or whatever key you want).To load that playlist in RR Or even in winamp.
    Then is it possible to press the numbered buttons on the remote then press a different button like the select button (or whatever) to then jump to that specific # in the current playlist..
    I have been playing around with this but can not seem to figure it out.
    I have a winamp plugin that does exactly this.But I want to do this in Girder.
    So right now I have 1 remote & Ir reciever to load the playlists with the plugin.
    Then another remote with a different Ir reciever for using everything with girder .
    Any Ideas on how to get this setup?
    Guys...
    Michael
    May 2005
    Vienna, VA
    you can try this.
    "LOADLIST" - This allows you to load a playlist from disk, with a custom name. You specify the full path and optionally
    the name of the playlist.
    Example: "LOADLIST;C:\Test.m3u;My Playlist"
  1. Best GPS Setup
    By buyos1717 in forum GPS
    Last Post: 08-20-2007, 02:35 PM
  2. Funky Girder Question / Problem
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 03-25-2006, 08:24 AM
  3. RR, Girder, and MJS Toslink Select ?
    By ajweinsh in forum Road Runner
    Last Post: 03-03-2006, 05:07 PM
  4. Replies: 7
    Last Post: 02-26-2005, 06:09 AM
  5. How fast of a computer needed for dual monitor (GPS & DVD) setup
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-23-2004, 03:29 AM
