Page 1 of 19 1234567891011 ... LastLast
Results 1 to 10 of 182
Thread: RR 5-2-06.. HQCT & More ..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 5-2-06.. HQCT & More ..
    A bit early for the monthly release cause I gotta travel for work this week. Still Lots of additions and fixes.
    I'm going to spend some left out donation money to get a copy of Mappoint 2006 to see what I can do with the interface. Just letting you guys know that I plan to work on it.
    This 5-2 version is basically the updates from Robby_BMW with the 5-1 version (many Thanks!):
    -Added the ability to fade-in the master volume when a call ends and the player restart (see the notes).
    -Added the ability to display caller's picture on the CALL_IN/CALL_OUT skins (see the notes).
    -Added the ability to disconnect the BT-Headset when PhoCo exits.
    -Added the "HEADSET_CONNECTED_PHOCO" indicator.
    -Added AM/FM indicator for HQCT support
    -Improved the command "PHONEDISCONNECT" that force PhoCo to disconnect and reinit the phone.
    -Improved the BT audio gateway support.
    -Improved compatibility with PhoCo 1.5.
    -Fixed isues with some old phones (like Sony Ericsson T68i).
    -Fixed issue with AddContact when in CallList.
    -Fixed issue with PHOCO.PST (see the notes).
    -Fixed various minors bugs.
    -Fixed RRConfig not loading "World" weather setting
    In version 5-1:
    -Added HQCT support (Major work)
    -Added support for Loadable Extension Plugins (Major work)
    -Added FastMode option to load screens faster (Major work)
    -Added SpeedFan Support (Thanks to deus_ex_machine)
    -Added Built In Voice Control support (Thanks to whodwho)
    -Added Dual Monitor support (Thanks to MatrixPC)
    -Added support to pre-load specified screens at startup
    -Added "WAIT" command to delay between multiple commands
    -Added "EVAL" command to evaluate expressions with variables
    -Added support for Thai language/charset
    -Added AutoIt SDK example (Thanks b8bboi)
    -Added label info XMFAVNUM/SRFAVNUM
    -Added ONSKINSTART event
    -Added support to execute secondary commands on press-and-hold of buttons (1 second holds)
    -Added COVERART indicator and label code
    -Added CPU Load slider support
    -Improved Album Art display to be layered as indicators
    -Improved List display of non-selected items to use all space available
    -Updated Delphi SDK example (fixed bug receiving messages from RR)
    -Updated RRConfig's Radio options
    -Fixed list highlight issue with trs=true
    -Fixed Issue with XMD1000 not updating current channel information
    -Fixed Issue with parsing Flash commands including '$'
    -Fixed Issue with ; appearing after custom FD labels
    -Fixed Issue with Text object font setting not working
    -Fixed Album Art Thumbnail Browse support not showing some thumbs
    Notes:
    -I still intend to add a little onto the extension plugin support (sliders etc)
    -FastMode is an ATTEMPT to make loading of screens faster (I basically added a way to load screens as it used to be on previous versions of RR) -- details on readme.txt
    -SpeedFan, DualMonitor and VoiceControl support was merged from the spin off versions posted here in the forums (many thanks to those who took the time to help the community).
    -Users of the Brushed skins that use album art, will notice that this version of RR will layer the album art BELOW the flash logo in the audio player. This was done to speed up and improve the way the album art display works and to make it more consistent with the way other imaging functions work in RR -- specially in what it comes to the VIS plugin. Unfortunately, there's no way to layer the flash logo UNDER the art, but it shouldn't be hard to make a flash plugin that displays the art when present or the logo of your choice when no art present -- anyone up for this challenge ? feel free to step in.
    -Pre-loading of skins actually works better than I expected, so you may want to give it a try -- look it up in readme.txt to know what to do.
    -Everything else you want to know you'll find either at readme.txt or skin commands.txt
    Again thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    May 2005
    Vienna, VA
    Awesome!!!
    Guino, did the issue with RR flashing in front when receiving a SendMsg get fixed in this release? I haven't had a chance to test it.
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    thanks guino, amazing job!!!
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by b8bboi
    Awesome!!!
    Should be fixed. This was a minor touchup I didn't put on the change list. I thought I sent you a PM about it.
    May 2005
    Vienna, VA
    Yes you did. Thank you.
    FLAC djmickyg's Avatar
    Feb 2004
    thanks!
    seems to be running a lot better than the past few versions
    and im likeing the pre loading of skins
    works real well
    thanks agian
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Another great release :-)
    p.s clicked on a couple of links for u
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Hey Guino, great release.
    Lets help and click on those banners
    The road is long but we are getting there.
    May 2005
    Vienna, VA
    I can write an IE bot to click on your links a bunch of times randomly.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i know this is probably a stupid question as its not referenced above but does this update include robby_bmw's phoco changes?
    Live mp3Car Facebook Chat
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
