Results 1 to 2 of 2
Thread: Keeping External Apps in Foreground
    Mar 2004
    Chicago, Il
    When i use the run command to launch an external application, it flashes for a second and then the rr menu reappears. Is there a way to have the applications stay on top?
    It turns out that the IBUSCOM.exe that sama made is whats causing RR to stay in the foreground. If anyone has figured out how to disable this, let me know. Thanks.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    To launch an application inside RR you should use the LOAD command and make a screen for it. The RUN command is meant to launch programs that run simple tasks and finish in a brief amount of time, meaning you shouldn't run full blwon apps with it (that's why it sort of works). There's a whole FAQ on launching an application embedded.
    Regarding IBUS flashes, you should be able to reprogram the commands from IBUS, add: SET|| in front of your commands.. this will prevent RR from flashing. For instance, if your command in IBUS is "NEXT" then change it to "SET||NEXT" this will prevent it from flashing when IBUS sends the command.
    Ride Runner RR's Myspace
  1. External Apps
    By netsuo in forum NeoCar Media Center
    Last Post: 12-20-2004, 03:38 PM
  2. External Apps - Having Problems
    By RobIles in forum Media Engine
    Last Post: 07-02-2004, 02:38 PM
  3. Running Embedded External Apps Like Mediacar
    By badandy4you in forum FrodoPlayer
    Last Post: 05-26-2004, 05:10 PM
  4. external apps
    By reda4 in forum MediaCar
    Last Post: 11-20-2003, 04:46 AM
  5. 2 or more external apps option...
    By cyrocr in forum ME Archive
    Last Post: 03-27-2003, 09:37 AM
