Results 1 to 10 of 10
Thread: RR performance and video card
    Constant Bitrate jac1502's Avatar
    Jan 2006
    I am not sure if this belongs in the hardware section or not, but because it is directly related to RR I put it here. I currently have a 16MB Voodoo3 video card, Amd 1.4 processor and 256mb ram. Would I help the performance of RR if I went to a better video card or where would my money best be spent performance wise?
    Apr 2006
    Depends on your "performance problem"! I have a 600 MHz with 256M and integrated on chip graphics and I don't have any problems with RR. What is really your problem?
    Jan 2006
    Well I guess I can not say I have a problem I would just like to make sure the screen change over speed is as fast as possible. I am following the RR tweak threads. I did notice some choppy DVD play back but I am using a usb 1.1 port on a 2.0 dvd drive so when I upgrade that hopefully it will solve that issue. I am fairly new to this and try to read as much as I can before I post but I wanted to get it in the car next week so if I had to buy a new card I wanted to do it now.
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    If your using an external (not on-board )anyway i doubt the graphics are a problem or will be,if i were you i'd get more ram and use the pre-loaded screens option from the new RR code
    Jan 2006
    when i preload the screens it has brief intervals of sound from each is there a way around that?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by jac1502
    What do you mean ?
    Ride Runner RR's Myspace
    Jan 2006
    Well I assume I was doing it correctly I was adding entries like in rrconfig:
    RADIO||TV||LIST||AUDIO||MAIN
    And for radio and audio and TV in my case I was getting sound form that function as the screen loaded
    Am I doing it wrong? Sorry I am very new to this.
    May 2005
    Vienna, VA
    of course you're doing it wrong. Get the latest RR and read ReadMe.txt.
    Code:
    preload=<FILENAME>.skin
    This allows you to pre-load specific screens when launching RR. You can add as many 'preload=' lines as you desire,
    but keep in mind this will increase the time necessary to load RR. It does however reduce considerably the time it
    takes to launch a screen for the first time -- virtually to the same time it takes when it's already loaded.
    Jan 2006
    Just out of curiosity what is that line in Rrconfig for? Just so that when RR opens it opens a specific function first not the main screen?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    that's one use for it. It's possible to execute any command though, meaning, it's not limited to launching a different screen.
  1. Video performance problem
    By IntegraKarim in forum General MP3Car Discussion
    Last Post: 04-05-2006, 01:43 AM
  2. Having trouble playing video
    By Keebortz in forum General Hardware Discussion
    Last Post: 07-27-2005, 08:18 AM
  3. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  4. need PCI nvidia video card with Conexant TV chip
    By Onyx in forum General Hardware Discussion
    Last Post: 11-12-2003, 04:14 PM
  5. tweaking video card w/ tv out
    By aye in forum General Hardware Discussion
    Last Post: 01-22-2000, 11:52 AM
