Results 1 to 5 of 5
Thread: C to F temp display change
    Constant Bitrate jac1502's Avatar
    Jan 2006
    I am trying to change my MBM temp display from C to F
    I read this post
    "You'll need to edit the .skin files (Notepad or Skin Editor) and change the tooltip to "c2f" of the MBM labels so RR displays them in F... RR receives the info from MBM in C so it needs to convert it to F, but this is only done when the "c2f" is on the tooltip of the label"
    But am not having any luck finding it in any of the files. Any help
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    did you read skin commands.txt ?
    the tooltip is the last field of the label definition. immediately after the label code "MBMXX"...
    Ride Runner RR's Myspace
    Low Bitrate slantman's Avatar
    Apr 2005
    north augusta SC
    code "MBM2"
    tooltip "C2F"
    Jan 2006
    I saw that but there was no tooltip there originally so I was not sure, I will try it when i get home!
    Oct 2005
    Oshawa
    learn metric!
    Hey Laserlips, your momma was a snowblower!!
  1. Dual Display Problem on M-II w/PowerDVD
    By DrDeriv in forum General Hardware Discussion
    Last Post: 04-11-2005, 06:16 PM
  2. Replies: 2
    Last Post: 03-01-2005, 01:59 PM
  3. How to change the time display
    By gerrylum in forum FrodoPlayer
    Last Post: 02-11-2005, 12:56 AM
  4. Stupid Xenarc! It won't turn on when laptop is on or display correct!!
    By PDiddy in forum General Hardware Discussion
    Last Post: 01-17-2005, 08:53 PM
  5. Replies: 5
    Last Post: 08-17-2003, 07:15 PM
