Results 1 to 4 of 4
Thread: CARCare some questions
    Dec 2005
    I have a some question on CARCare used.
    1. On start, the programm show a messagebox "Reminder Check". For this reason, CARcare don't embbeded, beacause waiting pessing Ok. That can I do at ExeTBL.ini for close this window.
    2. CARcare can be run a many copy of application. Can I do, that on switch to, example, weather and return next on CARCare, don't run a another copy of CARcare?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    as long as the program embeds propperly, RR will not run multiple copies of it. I don't know anything about the program though.
    Ride Runner RR's Myspace
    Dec 2005
    Quote Originally Posted by guino
    Ok, may be. Beacause app show a message box, it's don't embedded. May be for this reason run another copy of application. But what about first question? Can I press Ok button? SendKeys;{ENTER} don't work.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I hope you dont use the SendKeys command.
    The command should be "SENDKEY;{ENTER}"
    If else fails you can use an AutoIt script.
    WINACTIVE("{REMINDER CHECK}")
    WINCLOSE("{REMINDER CHECK"})
    When ever this reminder pops up run your AutoIt file. It will check for the active window and when it finds it it will be destroyed.
  1. Have several questions about Incar pc's
    By intuneauto in forum Newbie
    Last Post: 08-06-2005, 12:55 AM
  2. Bunch of questions .. New around here.
    By Timm3h in forum Newbie
    Last Post: 06-22-2005, 02:28 AM
  3. questions and more questions
    By cortinaking in forum Newbie
    Last Post: 06-16-2005, 03:02 PM
  4. Replies: 6
    Last Post: 05-25-2005, 12:53 PM
  5. Lots of questions.. long post.
    By rach in forum Newbie
    Last Post: 11-13-2004, 11:53 PM
