Results 1 to 8 of 8
Thread: Problem with DIRECTION indicator
    Mar 2004
    Stockholm, Sweden
    The DIRECTION indicator on my system is showing not the next turn but the turn after that (one turn too far ahead)... What i mean is if the next turn is Left and the one after that is Right, then MapMonkey/Destinator shows a Left turn, but DIRECTION indicator shows Right turn...
    If i change the following line in modMMDirections.bas:
    NextManeuvertype = .ManeuverType(CLng(MM_CurrentManeuver + 1))
    and remove the + 1 it works as it should.
    Is it only my system or has anybody else seen this?
    This is with Scandinavian map and Metric/International settins (km/h)
    Mar 2004
    Stockholm, Sweden
    Anyone ???
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't think there's a lot of people using this feature. If you use it and think it's wrong, I can easily fix it with whatever you tell me it's right.
    Ride Runner RR's Myspace
    May 2005
    Vienna, VA
    I believe somebody mentioned this problem. RR always shows one turn ahead of MM. Don't quote me on this though. I don't use MM so I don't know for sure.
    Mar 2006
    Italy
    When I used MM I have the same problem....I resolved it changed to Freedrive :|
    Mar 2004
    Stockholm, Sweden
    Guino, just remove the +1 on the line (see first post), this has been working great since I changed it...
    Mar 2004
    Stockholm, Sweden
    Guino, can you please change the following line in modMMDirections.bas:
    Please remove the "+ 1" to get MM direction indicator working, the line should read:
    NextManeuvertype = .ManeuverType(CLng(MM_CurrentManeuver))
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll remove it as soon as I have a chance.. Thanks.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-15-2005, 11:10 PM
  3. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 11:55 AM
  5. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 07:47 AM
