Results 1 to 10 of 10
Thread: RR keeps on freezing!
    Jerusalem
    Angry RR keeps on freezing!
    sometimes if i load the music 1st it would stop responding!
    all the buttons stop working! and it takes a lot of CPU
    its the newest version from april 2006
    i am using the base skin
    any ideas?
    93 MAZDA MX6 KLZE (sold :( )
    2005 STI :)
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    just a couple of things.. have you tried using a different version of winamp.. have you tried using a different skin.. Did t ever work fine on the system your running it on.. have you just upgraded your memory or anything like that ?
    CdR
    Jerusalem
    its a new system
    i am using the 2.95 winamp
    not changed the memory
    it did work fine at the start or i didn't notice it till i started testing...
    i will try another skin
    thanks
    2005 STI :)
    Jerusalem
    any ideas?
    it freezing on my other system too! both epia
    1st one is 5000
    the other is the 1300
    same software on both!
    2005 STI :)
    May 2005
    Vienna, VA
    Did you install flash?
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    Are you loading a super-large playlist? Mine sometimes freezes up for a few seconds if I'm loading several hundred tracks...
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    the only think i know of that will freeze RR 100% of the time is if you are trying to load an .exe file that is not present.
    beer replenishment fund
    mp3car live search
    May 2006
    Salt Lake City, UT
    I'm having this same problem ... any solutions yet? I've updated flash as explained in this FAQ High CPU Load, Buttons Fail to Respond, White box / square around logo's but still no luck.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Is the CPU load high ? can you produce a debug file ?
    Ride Runner RR's Myspace
    May 2006
    Salt Lake City, UT
    Quote Originally Posted by guino
    Yeah the cpu goes up to about 92%. I decided its been far too long since I've done a fresh windows install so I'm in the process of doing that and setting everything up again. If I still have the problem after that I'll let you know. Thanks guino ... you're the COOLEST!
  1. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 01:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
