Results 1 to 9 of 9
Thread: ONLINE tag picking up firewire as network?
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    On my test system, which isn't installed in the car yet, I have the onboard ethernet (EPIA MII-12000) and no other networking adapters... I'm using the ONLINE tag in the skin I'm working on, and it seems to be picking up the firewire port as a network, since the ONLINE tag is showing active. I have no cable hooked up to the onboard ethernet, so I'm thinking the only thing it could be detecting is the firewire, which often shows up as a network of its own...
    Anyone else experience this?
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    havnt seen this,
    try to disable the network connection for the firewire, that should fix it.
    beer replenishment fund
    mp3car live search
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    try disabling firewire if you don't use it through device Manager. I disable the 1393 controller on my MII and it works a treat, boots slightly quicker as well.
    regards
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Oct 2003
    Copenhagen, Denmark
    or use the inetup util to check for actual connectivity, description is included in the zip file
    http://www.rrdownloads.net/inetup.zip
    Not doing carpc anymore
    Low Bitrate Chamberlin's Avatar
    Aug 2006
    Tucson, AZ
    I just bought a Firewire/USB enclosure for my slot load DVD optical device
    and was hoping to use up the firewire port with this device... I know it's a touch slower than 2.0, but....
    I can't get it to recognize the 1394 device on my MII 1200 EPIA board...
    the port is enabled in the BIOS, and I also tried disablng the network attachment it normally has... The drive works fine on USB 2.0 connection,
    and I'll go that way if I have to, but I'd really like to use the 1394 port... is this port only for networking on this motherboard??? THe only drivers the EFUS enclosure came with were some Win98SE drivers on a floppy...
    thanks
    -C
    Jul 2005
    NJ
    This might not have anything to do with it, but it's possible that the firewire port on the MII12000 is not bus-powered, and that the firewire device requires its own power supply. Does the enclosure have its own power supply? If not, can you try it on a standard desktop machine and see if it's recognized there? You might want to research the MII12000 and see if the firewire port is self-powered or if it requires devices that have their own power supply...
    But as I said, I don't know if the firewire port is bus powered or not, so that might not be the issue at all, but it's something to look into.
    '01
    Aug 2006
    Tucson, AZ
    thanks black- yes I do have external power to the enclosure, a 5 volt lead off of my opus, which also supplements my USB 2.0 hub power. Everything works great USB, but I'd still like to utilize the firewire if possible... the EPIA only seems to recognize the port as a networking port... But you are right in that I should try
    the enclosure hooked up to a desktop firewire port..... just need to make a new AC/DC power supply as I hacked the cable
    thanks much
    -C
    Jul 2005
    NJ
    Okay, then the next things to try would be to connect a different firewire device (if you have one, or borrow one for a couple hours) to the MII12000 and see if it is recognized.
    Also, try reinstalling the firewire drivers for the motherboard and see if that makes any difference. You should be able to download them off the epia website.
    Also, you mentioned the device only came with 98se drivers, which I suspect could be the root of the problem. Try contacting the company for drivers for your particular OS, or scour their website for drivers.
    '01
    Aug 2006
    Tucson, AZ
    thnx black-
    I will try another firewire device and see what happens...
    Also, I think it only came with a windows SE floppy cause WinXP already has built in support for this connection and shouldn't need 3rd party drivers...
    but I will look on the VIA web site to see if there is new firewire drivers, although I think I already checked that... thanks again for your help
    -C
  1. Tag restoration
    By QnoisX in forum Fabrication
    Last Post: 07-02-2005, 03:53 AM
  2. ID3v2 Tag Reading VB6 Code
    By TheJack in forum Software & Software Development
    Last Post: 03-18-2005, 08:09 PM
