Results 1 to 4 of 4
Thread: Speed Warning
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Speed Warning
    Guino or other Gurus...
    I would like to make a Speed Warning Screen to pop up when the GPSSPD Label has a certain Value. Like
    If Label"GPSSPD">75 Then
    DoCmd "MENU;Speed.skin||Idle;5" else
    End If
    Are there any ways in RR to do that with MYVAR or SETVARBYCODE or thomething?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Right now, All you can do is use the overspeed indicator. Other than that you'd have to go with a flash based or SDK based solution. Should be very simple though.. with flash just monitor the GPSSPD label and if it's more than your limit execute an fscommand to load your menu (you could also monitor the overspeed indicator)... with SDK, you'd have to make a little background application that would request the GPSSPD and if more than you wanted, would send the command to RR.
    The problem is that there's no way currently to execute actions based on any label information.
    Ride Runner RR's Myspace
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Thanks Guino, I will do it with Flash or the SDK. I'll let you know the outcome.
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    In swishmax you can use parseInt(GPSSPD) to get rid of the m/ph, k/ph on the variable so that you can use the comparison IF statement. There should be something similar in FlashMX.
    Beer is proof that God loves us and wants us to be happy Benjamin Franklin
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Over speed warning
    By ShawJohn in forum FreeDrive
    Last Post: 11-03-2005, 07:25 AM
  3. Speed Camera Warning... Better Vocal?
    By Jaz in forum Map Monkey
    Last Post: 09-08-2005, 03:33 PM
  4. Replies: 2
    Last Post: 08-31-2005, 06:01 PM
  5. D3 Speed Limit warning
    By johnwharrison in forum Map Monkey
    Last Post: 01-18-2005, 05:45 PM
