Results 1 to 10 of 15
Thread: Question regarding Loadimg and flash
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    is it possible to load an image using the LOADIMG command on top of a flash movie? Here's basically what i wanna do. First pic is normal, second pic would be if iguidance is in guidance mode (thanks to igmod!) the image is just photoshopped for now. This would probably be easier in flash but i have NO programming skills. So what i'm doing is using an autoit script and exec.exe. Here is my code that loads the image
    Run("C:\Program Files\Road Runner\skins\MC2.5\exec.exe LOADIMG;170;127;205;200;600.jpg;OUT")
    Code works.. but image appears under the flash. Label still displays tho!
    Live mp3Car Facebook Chat
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Because flash goes on top of everything, you'd have to do it in flash. Other than that, all I can suggest you is that you make a discardable menu screen (as a popup) and run the command to load it when necessary -- it would display centered and on top of everything else. Then the same popup could use the TIMER event to close itsefl after a few seconds. This shouldn't be very hard to do, but let me know if you can't figure it out.
    Ride Runner RR's Myspace
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    Question: Can he get the graphic in the right position if he creates a full pink image with 4 one-pixel dots on the corner edges and the image in right place? I'm not sure if RR can act like this?
    EDIT: Sonicxtacy02, your webpage crashed my computer. lol
    Beer is proof that God loves us and wants us to be happy — Benjamin Franklin
    guino's Avatar
    Nov 2004
    Toronto, Canada
    yes, if you make that pink transparency for the empty image it will work. you don't need the 4 pixels though.. RR centers the screen by the original size and not by the resulting transparent window. You don't even have to have the full screen size, just enough to be centered at the desired position (because menus will always be centered).
    So this should work too:
    Woodbridge, VA
    Blog Entries
    32
    gonna try to do this today. Will post results
    My website is truly outdated. Since i started doin all this road runner crap its turned into a mixing bowl of conflicting java and flash scripts lol. Link removed
    Woodbridge, VA
    Blog Entries
    32
    i got it working (sorta) the non-flash way but i'm gonna attempt to do it in flash now as it does seem like the cleaner solution. I have the basic elements and tweens down now i just need to learn the scripting. I guess i should ask before i start if its possible to put a flash movie on top of another flash movie. Else i'll have to add it to the main.swf already on the skin.
    Woodbridge, VA
    Blog Entries
    32
    flash guru's ... i need your help!
    I'm having no luck doin actionscript. All i really need is to check if iguidance.exe is running. If so have the graphic in the "down" position, if not have have it in the up position (out of the stage area hence invisible). The Play() command makes the graphic just loop as if its in the test movie window.
    Woodbridge, VA
    Blog Entries
    32
    ugh cant get the two flash movies to play nice with each other. Oh well looks like i'll have to do it the non-flash way.
    Mar 2005
    Concord, California
    try asking CdR for the origional .swi file... He might be kind enough to let you mod it for this.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    FD already has inbuilt indicators / eta / etr which only appear if routing with freedrive.. I will make the file available if anyone wants to play. Please remember MC was one of my first attempts with flash, so its not the cleanest of coding.. let me know if you want it and I will post it in the first post of the ~MC1.0 post
    CdR
