Results 1 to 3 of 3
Thread: Phoco error with no phone on RR startup
    Nov 2005
    Missouri
    I'm sure this issue has been raised but when I search I get so many results that appear to be obsolete (due to improvements in RR).
    Phoco works just fine (as long as the phone is attached). Note I am using a phone with usb cable connect (no bluetooth).
    But when I start RR with no phone connect, or with the phone already dialed into the internet Phoco fails to start (as you would expect). And I get an error message "Opening the Communications Port Failed"
    Is there anyway to avoid this. Ie. dont try to start Phoco if there is no phone (how would RR know if there was no phone?)
    Thanks...Paul
    May 2005
    Vienna, VA
    The problem is on Phoco side. Try starting Phoco outside of RR to see if you have the same error.
    Nov 2005
    Missouri
    Quote Originally Posted by b8bboi
    Your right. For some reason I thought Phoco closed without an error.
    I'll ask on the Phoco forum
  1. RR and Phoco some issues
    By kocke in forum Road Runner
    Last Post: 04-01-2006, 12:47 PM
  2. Minimize winamp on RR Startup
    By Shelbrain in forum Road Runner
    Last Post: 05-26-2005, 02:09 AM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
