Results 1 to 10 of 13
Thread: Rr Vis
    May 2006
    Rr Vis
    I'm probably gonna get ripped into but I searched the forum can't seem to find an answer.
    Just running roadrunner on my laptop to make sure i know how to use it first and what not...loaded some music and its great. So far I love this front end its just perfect in my mind.
    But when I click on the visualization button nothing comes up, do I have to install something else, does it even open as a part of the roadrunner screen instead of lets say the playlist or something? Any advice would be helpful, thanks
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    setup vis options in rrconfig.exe
    use classic skin in winamp
    beer replenishment fund
    mp3car live search
    May 2006
    I see
    Visualization Plugin :
    O Milkdrop O AVS Window O Other(window title) [textbox]
    Elsewhere
    So choose one!
    How about the Wiki?
    May 2006
    Quote Originally Posted by DarquePervert
    So choose one!
    None of them work!
    No matter which I choose when I click on the visualization button nothing happens.
    Variable Bitrate jthiani's Avatar
    May 2005
    Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
    you have to match the choice in rrconfig to the available choices in winamp (i think)In other word, the vis you want to use must be installed in winamp before rr can use it ( guino correct me if im wrong)..... so close rr and open winamp,then open the vis config screen ( right click in winamp title bar; visualiation; select plug-in) i use either 'advanced visualization studio' or the 'sexy attached analyzers' . Once you confirm the vis you want is installed and working ( you should test in winamp just to make sure it works....) it time to get the class name (using winspector spy How to embbed any Application in RR ?) of the vis window. now close winamp and open rrconfig and enter this info into the vis section. If the vis your using is not listed, choose 'other' and enter the class name in the box with an exclamation mark (!) infront of it. Save and viola your done. It should now work.
    If it doesnt work, pray, repent your sins and try again LOL !!!!!!!!!!!!!!!!
    Aug 2005
    AVS is built in to winamp IIRC, but you need to download and install milkdrop. You will also need to go in to the milkdrop configuration and uncheck integrate with winamp or you get a stupid border around the vis. Milkdrop is pretty CPU intensive on ITX systems or at least in my experience.
    May 2006
    Quote Originally Posted by Silentbob343
    Where can i get milkdrop?
    I'm running a pentium 4 so maybe it wont be as intensive i duno?
    May 2005
    Vienna, VA
    Dude, do you ever search? Do a Google for milkdrop.
    Aug 2005
    Quote Originally Posted by V6Stang
    Quote Originally Posted by b8bboi
    lol
    as b8bboi said just google "winamp milkdrop" you should have no trouble finding it.
  1. Vis and RR
    By mrharrod in forum Road Runner
    Last Post: 05-12-2006, 08:34 AM
  2. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 01:17 PM
  3. RR and Winamp VIS...
    By DaPCWiz in forum Road Runner
    Last Post: 11-01-2005, 06:17 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 08:14 PM
