Results 1 to 10 of 15
Thread: Ideas for RR
    May 2005
    Germany
    Ideas for RR
    Hello,
    what do you think about an option, while driving video stops.
    For example:
    While the car is parking you can watch a video or dvd, but when you start driving, video stops automatically and play music, when you stand again, RR switch to dvd/video and play where it stoped. Maybe this could made by reading the gps-signal. The speed could be set in the rr.config like:
    pause-video-while-driving: 5 km/h
    What do you think?
    Ti-ejtsch
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    I don't think that anyone wants this feature. BTW, in germany it's not legal to have a carpc installed in the car anyway.
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    I think its a good idea. I don't see it being very complicated to do.
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
    Registered User
    I think its a good idea too.
    Raw Wave lostreception's Avatar
    NY
    Quote Originally Posted by Ti-ejtsch
    Hello,
    For example:
    What do you think?
    Ti-ejtsch
    if guino doesnt add this as a feature a small prgram or script can be made quite easily
    ill do it if he cant add it to rr itself
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    1. there are some who will be dual screens and the video will be on the secondary monitors, so this is not a good option.
    2. Using the GPS is a bad idea, as there are times when you might not have GPS signal, so it wouldn't shut it off. Not a workable option.
    If you want it, you need a hardware solution that works off the handbrake.
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    How about just not playing videos while driving? Why have someone else work on coding the program when all you have to do is keep your hand off the "Video" button?
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I would say if someone wants that feature for legal purpose then a signal from the engine should be used. Engine running>>>No Video. Or on an Automatic use the park position switch. Hand brake is just not up to par with this. I can loosen up the hand brake cable a little and then pull the hand brake one notch to get it off the switch and your hand brake is not engaged at all.
    May 2005
    Germany
    Hello,
    if I could write why I thought about this maybe you would understand. But I will receive a mail with the translation from my aunt. Soon I post it here.
    I wrote that it should be in the rrconfig by setting a speed, so if you don´t want it, don´t use it.
    Ti-ejtsch
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    I'm sure your thinking of this from a legal standpoint so it would have to be a hardware thing otherwise you could just exit RR and play video anyway.Legally this leaves you back where you started so it needs to go deeper than RR.
  1. RAM movement causing problems!! Need Ideas!!!
    By techy101 in forum General Hardware Discussion
    Last Post: 11-25-2005, 01:11 AM
  2. Newbie Ideas
    By codyman in forum Newbie
    Last Post: 03-14-2005, 11:03 PM
  3. CarPC Brainstorming Ideas
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 12-27-2004, 03:40 PM
  4. Mounting idea's for a Mazda RX-8???
    By glxyjones in forum LCD/Display
    Last Post: 06-08-2004, 01:29 PM
  5. help with ideas for a total homebrew mp3 car player
    By acidic in forum General Hardware Discussion
    Last Post: 07-12-2002, 12:02 PM
