Results 1 to 4 of 4
Thread: RR (RoadRunner) and IBUS
    Registered User
    Aug 2004
    Hi CDrSkull and everyone else
    I have yet another problem with my setup.
    Computer Specs:
    epia M10000
    512 ram
    120GB HD 2.5"
    IBUS module (serial version) No USB
    ok
    Software
    Ibuscomm .ini file
    Latest Update of RoadRunner
    I had this running before, so i know it works. It doesn't work anymore becuase i reformated my computer After reloading windows XP and SP2, iBUS+RR does not work anymore. I'm not quiet sure if a driver is needed to have this module to work becuase i forgot what i did before
    so...my problem is: whenever i run RoadRunner then ibuscomm (or vice versa) i get this "run time Error 13" message. WTF? now this is in my carputer setup.
    Going to my Laptop with the same RoadRunner + ibuscomm...it detects it and tells me no open commport. <--- that i understand because its not hooked up to my BMW. But as far as the carputer, the serial is working (tested it with ibus analyser). i just get that message
    What is going on?
    1. does my laptop have some drivers that my carputer does not have?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    That error happens when assigning data of a different/invalid type to a variable. Could be some weird setting like:
    SYnchronizeClock=
    In any case, doesn't sound like a missing file.. you said you ran the same RR+IBUSSCOMM, but I assume you used the same settings too ?
    Ride Runner RR's Myspace
    Registered User
    Aug 2004
    yes same settings, same files used as before... i cannot figure it out. Could it be the new version of RR?
    what's strange is that it works on my laptop, but not on the carputer.
    I don't know if it matters, but i tried winamp 2.95 AND winamp 5.0. Still no luck.
    Registered User
    Aug 2004
    where can i find old versions of Road Runner?
  1. IBus and RR
    By bes51659 in forum Road Runner
    Last Post: 06-19-2006, 02:15 PM
  2. BMW iBus interface not working anymore
    By aiml27 in forum RR Bug Tracker
    Last Post: 02-22-2006, 12:24 AM
