Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Guino: Add to High CPU Load FAQ
  1. #11
    Nov 2005
    I always use the flash.ocx from Guino's page or the rrdownload mirror page.
  2. #12
    Jul 2006
    can someone please clarify the registration issue and when it occurs? i followed the instructions in the faq: High CPU Load, Buttons Fail to Respond, White box / square around logo's
    I installed flash using the download given there, and then unzipped the files from the zip into the directory. I then renamed Flash8.ocx to Flash9.ocx. I did not receive any errors during this process, nor did I ever have to type regsvr32 flash.ocx. But my roadrunner still goes pretty slow (PIII 850mhz, 256mb ram) with the mc2.0 skin. Am I missing something, at what point was I supposed to do the regsvr? I dont even have a flash.ocx in my system32 directory, only in the system32/macromed/flash/ directory
  3. #13
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Flash heavy skins (MC 2/Freedom etc) do require more processing power as flash has no hardware acceleration support. If you've followed all the suggestions on that FAQ thread than your computer is probably just too slow to run flash (850Mhz is not much). I'd suggest trying a non-flash skin or a light one at best.. see if it helps.
    Ride Runner RR's Myspace
  4. #14
    Variable Bitrate wfs1's Avatar
    Oct 2005
    Try this,
    In your display properties of windows, goto the troubleshooting tab, then under the hardware acceleration move it down a notch from full...
  1. Replies: 4
    Last Post: 07-10-2005, 02:31 PM
  2. CPU load at 100%
    By RPMkeeper in forum Centrafuse
    Last Post: 04-18-2005, 03:02 PM
  3. High cpu usage when audio is muted.
    By Arathranar in forum RR Bug Tracker
    Last Post: 03-23-2005, 03:51 PM
  4. Replies: 8
    Last Post: 10-17-2004, 11:59 PM
