Results 1 to 3 of 3
Thread: speedo hangs when starting MM
    Low Bitrate Flappy's Avatar
    Jun 2004
    Netherlands
    I don't know if i put this in the right part of forum, but here it goes:
    My system runs (almost) succesfully for several months now. Since i added GPS, little trouble came up. I use Xport to split my gps signal from COM3 to COM4, 5 and 6.
    I use COM4 for Roadrunner, 5 for MapMonkey and 6 for Netstumbler. The speedo in RR works fine, but when i start MM, the speedo in RR hangs. Even when i close MM, it still won't work again, unless i reboot ofcourse.
    Also since my use of Xport (that solved my 'COMM PORT IN USE' problem), Windows won't shut down automaticly anymore. RR exits perfectly, but MM says: "trying to shut down, click here to shut down the program", or something like that. If i don't select that option, it won't shutdown, so i drain my battery if i forget.
    Any suggestions?
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    there is a force kill option somewhere in windows that when shutting down it will force any hung apps to get killed, i think you set it in the registry somwhere, you'll have to google it.
    i dont use MM or xport but have you tested each port for gps data at the same time. By say running 3 gps apps and see if they all navigate properly. It may be an issue with xport as far as teh speedo lablel failing
    beer replenishment fund
    mp3car live search
    Jun 2004
    Netherlands
    Quote Originally Posted by liquid_smoke
    MapMonkey and Netstumbler works fine together, only RR speedo will hang as soon as i start MM.. Also, the speedo in RR is very slow, takes about 5sec before it gives the right speed, but i guess that's normal, RR isn't a navigation program, the speedo is just a nice extra.
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 02:02 PM
  2. Allowing MM to remain on top?
    By Ashthos in forum Road Runner
    Last Post: 10-31-2005, 07:40 PM
  3. Problems with MM Advanced Mode/SiRF
    By RoyN in forum Map Monkey
    Last Post: 04-24-2005, 11:49 AM
  4. SENDKEY & MM Embedding
    By ruairi in forum Road Runner
    Last Post: 04-04-2005, 04:36 PM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 06:27 PM
