Results 1 to 10 of 11
Thread: How to easily access the Control Panel
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Here's how I added easy access to the Control Panel from within RoadRunner via the Apps Menu.
    Browse to where you have RoadRunner and open the LAUNCH folder
    Create a new folder and call it Control Panel
    In the \Control Panel\ folder, create a file called Control Panel.ini
    Add these lines inside the .ini file
    Code:
    [GENERAL]
    PATH = Control.exe
    TryEmbeddedTimeout = 5
    WindowSearchString=Control Panel
    Restart RR if its running
    Now you'll have the ability to open up the Control Panel from the Apps menu.
    Derek
    EDIT: Or if you're running dbassix's modified version, you can simply use the RELOADINIS command to refresh the .ini files and load any modifications that have been made.
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Mar 2002
    Austin, Texas
    Or just simply download the .ini and put it in a folder called Control Panel in the LAUNCH directory. Just be sure you save it as an .ini file instead of a .txt file.
    Derek
    Attached Files Attached Files
    Constant Bitrate dbassix's Avatar
    May 2005
    Dresden / Germany
    But than u have to restart Roadrunner. Or you need my moddified version with the added "RELOADINIS" Command.
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    Mar 2002
    Austin, Texas
    A simple RELOADSKIN may will also work but I don't think may skins have that command enabled. Hence, the reason why I said to restart.
    These instructions follow the K.I.S.S. method of doing things.
    Derek
    May 2005
    Dresden / Germany
    RELOADSKIN wouldn't reload the inis, so it's quiet worthless.
    I added a command called RELOADINIS to RR, so u can put a button in the skin which will just reload the inis and reset rr.
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Mar 2002
    Austin, Texas
    Quote Originally Posted by dbassix
    Regardless of the facts, a restart is going to be the easiest thing to do. I'm willing to bet that more people are running guino's build of RR than your build. On top of that, you didn't even say where to get your build of RR. Someone can have their computer restarted in a shorter amount of time than it would take to try to search for your build. Until guino adds this capability to RR and skinmakers incorporate it into their skins, the instructions will remain as restart the computer.
    Derek
    Aug 2005
    Someone could have also restarted in the time it took you two yahoos to argue this out...
    Now kiss and make up...
    May 2005
    Dresden / Germany
    d_sellers:
    As i said, it's MY modified version.
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Banned JagPuter's Avatar
    Apr 2006
    My Garage
    Off topic, Stupid flame, end it now this is a getting lame....
    May 2005
    Vienna, VA
    seriously
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  1. AIMEE Climate Control POLL
    By Danceheaven in forum Software & Software Development
    Last Post: 01-14-2010, 10:38 AM
  2. Control panel crashes explorer
    By n8scstm in forum General MP3Car Discussion
    Last Post: 06-30-2008, 06:30 AM
  3. AC97 Control Panel Switcher Program (could be useful for many)
    By Vinister in forum Software & Software Development
    Last Post: 02-02-2005, 04:50 PM
  4. Replies: 14
    Last Post: 02-26-2002, 09:42 AM
  5. LCD + control panel almost done
    By RWAudio in forum General Hardware Discussion
    Last Post: 05-24-2001, 06:43 AM
