Page 3 of 10 FirstFirst 12345678910 LastLast
Results 21 to 30 of 91
Thread: RR 06-03-06 .. Few Improvements ..
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    well, no matter how I show the OSK, you can always use clipping and such to make the OSK appear in the desired position.. I just need to know what should be the default/standard.
    Ride Runner RR's Myspace
  2. #22
    May 2005
    Maybe you can design it to use the tooltip for the Y alignment, something similar to Labels. We can have "TOP", "CENTER" and "BOTTOM". TOP will display the OSK top down, CENTER for what it is now and BOTTOM for displaying the OSK bottom up. You can have CENTER as the default if it is not specified. Last but not least, I think this should be implemented for all OSKs. ie APPOSK, APPOSKX and NUMOSK.
  3. #23
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    This version seems to be a little more peppy than the previous version. My system seems to load screens just a little more quickly now.
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
  4. #24
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Quote Originally Posted by 01black_ac
    '01
    I second that
    2001 S10 ZR2
    Chucks Skin - to old
  5. #25
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    Third it.
  6. #26
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    I don't know if this is going on with anyone else, but RR will run fine for 10 min or so and then all the sudden it will just freezes. Funny thing is the music continues to play I just cant skip, go back, or make any kind of changes. It started back in April and has been doing it since. I was hoping that by updating it that would fix the problem but no. Anyone else having the same problem, I'm using the MC2 skin by the way. Thanks to everyone in advance.
  7. #27
    Aug 1999
    Have you tried using a different skin (silly question, i know) to see if it's possibly just that skin that is causing the issue?
  8. #28
    Apr 2003
    Oklahoma
    You know I haven't, I will try that. Thanks for the fast responce. I have been so stuck on MC2 that I didn't even think about changeing the skin. It's the only one I really like. Thanks again replicant!
  9. #29
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by reggiek945
    Verify you don't have any settings you don't use setup (XM/SIRIUS etc), and if you do have those options, try disabling them to see if the problem goes away.
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I've had that, haven't run this version but it started on the first version that included voice control. I put it down to the fact I have voice control enabled in the ini but disable it when it starts as the voice control is being a problem. (due to where the mic is not the function).
    I'm running the iDrive skin funnily enough
  1. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  2. RR 07-15-05... More improvements..
    By guino in forum Road Runner
    Last Post: 07-21-2005, 08:49 AM
  3. RR 05-06-05 ... Improvements ...
    Last Post: 05-12-2005, 12:10 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. RR 03-07-05.. Few Improvements..
    Last Post: 03-07-2005, 07:44 PM
